fork oil
Re: fork oil
doesn't matter, im going with 15W fork oil.
- warren3200gt
Re: fork oil
Add in 1/2 inch of pre load also, to counter that initial nose dive
Re: fork oil
warren3200gt wrote:Add in 1/2 inch of pre load also, to counter that initial nose dive
not quite sure what you mean by that ?
- warren3200gt
Re: fork oil
Before fitting the top caps compress the spring add in 1/2 spacers (coins do a good job) then fit the top cap. The spacers pre compress the springs and take up the initial nose dive softness.
Re: fork oil
warren3200gt wrote:Before fitting the top caps compress the spring add in 1/2 spacers (coins do a good job) then fit the top cap. The spacers pre compress the springs and take up the initial nose dive softness.
Ah got yah, the springs I used came out of a SR 650 which are about 10mm longer, I'll see how they go.
Users browsing this forum: No registered users and 81 guests
