Z1000J wiring loom
Z1000J wiring loom
#1 PostAuthor: paul doran » Wed Sep 03, 2025 9:44 am
I am looking for a Z1000J wiring loom if anyone has a decent one they would like to sell
Simonic
Re: Z1000J wiring loom
#2 PostAuthor: Simonic » Wed Sep 03, 2025 2:59 pm
The Z1000R one is available. I believe they are almost the same.
elr-21
#3 PostAuthor: elr-21 » Wed Sep 03, 2025 4:09 pm
That is wrong.
Check out the clocks and you will see some differences...
KERKER kicks ass!
Simonic
#4 PostAuthor: Simonic » Wed Sep 03, 2025 4:20 pm
elr-21 wrote:That is wrong.
It depends which year J you are talking about. The J3 has the same clocks as the R. I know this because i own a J3
#5 PostAuthor: paul doran » Wed Sep 03, 2025 5:23 pm
Clocks on my J are operated by the following speedo by electronic drive from the wheel and rev counter electrically
Simonic
#6 PostAuthor: Simonic » Wed Sep 03, 2025 5:41 pm
paul doran wrote:Clocks on my J are operated by the following speedo by electronic drive from the wheel and rev counter electrically
Hi Paul. Your bike is J1 or J2 then. Cheers
redzee
#7 PostAuthor: redzee » Fri Sep 05, 2025 7:01 am
Confirmed as correct, I have J3 too, speedo is cable same as later 1000R and 1100R
Eight valve grunt.
