Ignition Switch wiring short. Z1000 A2 1978
#1 PostAuthor: ADRIAN H » Fri Sep 12, 2025 6:13 pm
What would cause the Brown wire in the Ignition switch connector block to short out. I went out for a ride, came home. Next day turned the key on, no power at all. Noticed the brown wire on the ignition switch connector block had shorted out. I have bought a new connector block, which is now fitted - but there is still no power when key turned on.
Kev1R
Re: Ignition Switch wiring short. Z1000 A2 1978
#2 PostAuthor: Kev1R » Fri Sep 12, 2025 8:53 pm
Possibly a fault within the switch itself?
I might have a spare I could post to you to try.
Obviously you've checked for blown fuses?
Let me know if you want to try a different switch & i'll have a look to see if I've still got it.
#3 PostAuthor: ADRIAN H » Sat Sep 13, 2025 7:34 am
Kev1R wrote:Possibly a fault within the switch itself?
Thanks for the kind offer, I thought it may be the switch so I ordered one from Zpower last night. :up
Mark Tiller
#4 PostAuthor: Mark Tiller » Sun Sep 14, 2025 4:57 pm
wiring that runs inside the bars is a weak point for the insulation wearing thru and blowing the fuse
07962421462
#5 PostAuthor: ADRIAN H » Mon Sep 15, 2025 7:32 pm
Mark Tiller wrote:wiring that runs inside the bars is a weak point for the insulation wearing thru and blowing the fuse
Thanks.
