Wanted Z1R Z1000D frame or rear section
Gus
#1 PostAuthor: Gus » Tue Nov 18, 2025 5:50 pm
Hi Guys.
I have a UK Z1R frame and V5 in my name but previous owner/s cut the back end off.
Looking for a Z1R, Z1000D frame or rear section.
I need the rear section to include lock mount.
Damaged, rotten, no numbers or V5 considered.
Cheers.
Gus
"Set the GRINDER on it"
Borno3
Re: Wanted Z1R Z1000D frame or rear section
#2 PostAuthor: Borno3 » Thu Jan 01, 2026 9:15 pm
Theres been a frame on marketplace for a while , not sure if you may have seen it , its a bit ropey
https://www.facebook.com/marketplace/it ... _code=null
Gus
#3 PostAuthor: Gus » Fri Jan 02, 2026 10:36 am
Thanks for that I'll keep an eye on it.
Much appreciated.
neilbarrett
#4 PostAuthor: neilbarrett » Fri Jan 02, 2026 7:31 pm
Have you a pic of the part you want as I've a frame I want rid of
Gus
#5 PostAuthor: Gus » Mon Jan 05, 2026 10:20 pm
Thanks Neil.
I'll try and get photos in the morning.
Much appreciated.
Gus
Gus
#6 PostAuthor: Gus » Wed Jan 14, 2026 9:22 pm
neilbarrett wrote:Have you a pic of the part you want as I've a frame I want rid of
Apologies Neil.
My frame is at a friends workshop and he died a couple of weeks ago.
As of yet I don't have access to get my stuff back at the moment.
Cheers.
Gus.
compo z1r
#7 PostAuthor: compo z1r » Wed Jan 14, 2026 11:52 pm
i have neil he requires back end ? from indicator plates back
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Gus
#8 PostAuthor: Gus » Fri Jan 16, 2026 8:38 pm
Cheers Compo.
Hope you are well my friend.
Much appreciated.
Gus
#9 PostAuthor: Al » Sun Jan 18, 2026 7:03 pm
Message sent
Gus
#10 PostAuthor: Gus » Tue Jan 20, 2026 5:35 pm
Al wrote:Message sent
Hi Al.
If the message was for me, there is nothing in my inbox?
#11 PostAuthor: Al » Tue Jan 20, 2026 6:12 pm
Hi Gus yes the message was for you regarding a Z1R frame but it was an e-mail not a pm sorry if it didnt come through.
I have re-sent but as a pm with my phone number on it.
Gus
#12 PostAuthor: Gus » Fri Feb 20, 2026 6:42 pm
Does anybody know if the rear bracket on a Z1R is the same as a MK2 or have some photos for reference?
Cheers.
Gus
#13 PostAuthor: Z1streetfighter71 » Fri Feb 20, 2026 6:46 pm
If you are talking the bracket that holds the light and the cowl, then yes. I have the rear tail cowl of a Mk2 and can show you it fitted to a Z1r frame.
Gus
#14 PostAuthor: Gus » Fri Feb 20, 2026 7:23 pm
Yes please
Big Fluff
#15 PostAuthor: Big Fluff » Sat Feb 21, 2026 10:33 am
John Browse has literally 100's of Zed frames.
