standard clocks
standard clocks
hi all, if i put a 17'' front wheel in z900 is it posable to get the speedo recalabrated?
phil churchett
Brian,
I had one of those kph - mph converted gear box thingy-ma-gigs on me old Gixxer......
That slows down the revolutions from the wheel to fool the kph speedo & therefore you can read it as mph
This will have the same effect, so if you fit a 17" wheel....
Won't be spot on but not far out.
I can't be arsed to calculate the difference
