Sadly too bad to go out today so I`ve started on the carburettor rebuild on my Thou`.
Someone has used Black gasket Goo around the intake rubbers previously and I need to get rid of it before I clean the carbs up.
Any ideas on the best way to remove it ? Bearing in mind it`s on a rough casting so sticks like sh*t to a blanket !
Instant Gasket Removal
Permatex "Ultra Black" is a top quality sealent made in the US of A....
They do grey & other colours too..... as used & recommended by Debben Performance... although they don't necessarily say on manifold rubbers
I also use the Copper Permatex on the barrel 'O' ring channel when using a 1-piece gasket
