right hand side caliper for z1
i need a right hand side caliper for my z1,i say the right hand side,as you are sitting on it,just won some forks on ebay,now need brakes,someone must know were there is one.
- foreverinthegarage
- Regular Poster
fredswat
Twin Discs
I have converted my Z1B to twin Discs
You will need
RH caliper mtg Brkt - Z1 Enterpises do them
additional caliper & disc
Dual brake hose splitter & brake stop lamp switch assembly
additional hose & metal pipe (from splitter to caliper )
RH hose brkt - Mounts between forks and front fender
5/8 bore master cylinder as the single disc one is not up to operating 2 discs
You will need
struthe lads,do i need a better paying job,i think i need the one with iron pipe,the forks i have are off a z thou ,just got a set of forks with the chrome reflectors on ebay,and would like the caliper on the usa ebay,as that one would pair up to the one i already got.
