Pilot Jet blocked?
dave3d
Pilot Jet blocked?
#1 PostAuthor: dave3d » Fri Feb 20, 2009 12:13 pm
I've got a lovely little pilot jet in my hand - but no clear view through the shaft.. Trying to clean it and blow it out but boy is it jammed thick with crud. Am I supposed to see daylight through it, or are there hidden bends best left well alone.
thanks...
bunnysZ
Granny Magnet
#2 PostAuthor: bunnysZ » Fri Feb 20, 2009 1:37 pm
if you close one eye you should see daylight through it,
common prob, when cleared fit petrol filters
dave3d
#3 PostAuthor: dave3d » Fri Feb 20, 2009 2:17 pm
mm, the pilot in the next carb is the same. Totally blocked, no air passing thru and needle won't go thru either. Strange
tlc
#4 PostAuthor: tlc » Fri Feb 20, 2009 2:53 pm
The crud that collects in carbs is tough indeed. I rebuilt mine using Keyster carb kits. Those bits that weren`t included I carefully cleaned and cleared any passages with a cocktail stick !
I also put the whole carburettor bodies through a dishwasher.
Caveat. Dishwashers use salt, so be sure to rescue the bodies immediately the cycle has run and dry thoroughly. Also dowse in WD40 to clean afterwards.
bunnysZ
Granny Magnet
#5 PostAuthor: bunnysZ » Fri Feb 20, 2009 3:48 pm
sticky bowl , blocked jets , ... has your bike been standing a while , should think the carbs are blocked somewhere else as well, get them a deep clean and solve all the problems at once
Magnum1
#6 PostAuthor: Magnum1 » Fri Feb 20, 2009 6:14 pm
Get a saucepan and boil them up in lemon juice. Don't poke them with anything metal or hard, it will fuck them up.
Rod
Never heard of a Harris Magnum
#7 PostAuthor: Pigford » Fri Feb 20, 2009 7:05 pm
#8 PostAuthor: zed1015 » Fri Feb 20, 2009 9:04 pm
Buy an ultrasonic cleaner, They are cheap on ebay. Gets carb parts and anything else like new. You can watch the muck float right off even after you've done your best with the soak in petrol and air line thing.
#9 PostAuthor: Ginger Bear » Sat Feb 21, 2009 5:36 pm
You could try soaking in thinners, but don't poke them with anything sharp. I tried everything to sort mine & in the end bought an ultrasonic cleaner & now wonder how I ever managed without it!
dave3d
#10 PostAuthor: dave3d » Sun Feb 22, 2009 9:16 am
oh **it, too late, poked 'em with a needle.. new jets?
#11 PostAuthor: Pigford » Sun Feb 22, 2009 10:06 am
REPEAT: http://www.allensperformance.co.uk/index.html
For all your carb bits & bobs... :wink:
#12 PostAuthor: Rich » Sun Feb 22, 2009 3:45 pm
Euro / dollar Jeff at Z1
jakeymara
carbs
#13 PostAuthor: jakeymara » Sun Mar 08, 2009 9:01 pm
Tried to get mine to even fire up today to go for a spin, but no chance. I turned her over 2 weeks ago, a little rough but all 4 pots were working.
Plugs are sparking nicely so suspected carb/ fuel. Drained the carbs, put fresh fuel in but nothing. Fuel is getting into the bowls but it seems fuel/ air mix is not getting to the cylinders so I have to suspect the jets are blocked.
If I get a sonic cleaner jobber, can I use it to clean the pilot, main and needle jets/ air bleed pipe, or do you recommend new ones?
Best place for gaskets/ jets is Allens Performance as Pigford suggests?
Taffus
Re: carbs
#14 PostAuthor: Taffus » Sun Mar 08, 2009 10:21 pm
jakeymara wrote:Tried to get mine to even fire up today to go for a spin, but no chance. I turned her over 2 weeks ago, a little rough but all 4 pots were working.
Yes, you can use the ultrasonic cleaner for that thread here
http://www.z1ownersclub.co.uk/forum/viewtopic.php?t=8101&highlight=ultra+sonic
Taffus
#15 PostAuthor: Taffus » Sun Mar 08, 2009 10:23 pm
Only a similar note......
cleaned my carbs over this weekend to get rid of a flat spot at 6k which has got progressively worse.
No more flat spot, runs on 3 at idle, Bugger
