5/8" Offset sprocket
#1 PostAuthor: zed1015 » Fri Mar 27, 2009 10:57 am
Wanted - 5/8" (15mm) offset, 17t , 630 pitch front sprocket with bearing nose for zed 9/1000. Or 19t ,530 pitch with bearing nose. Don't mind s/h in good nick.
Keefleaf
#2 PostAuthor: Keefleaf » Sat Mar 28, 2009 11:18 am
I think a Gpz 750 turbo drive sprocket might do it,worth a check.
greenlaningxt
Sproket
#3 PostAuthor: greenlaningxt » Sat Mar 28, 2009 4:31 pm
You can get a billet one of Debben.
I have a 630 16 tooth one on the Harris, he did not think I would get away with the 17 tooth.
I have Hydralic clutch but still think I might try a 17.
What you fitting it to, whats the tyre and rear sproket size?
The GPZ one is offset but only 15 tooth, I have one somewhere, not been able to find any bigger standard type.
Let me know if you do find one!
Harris Z1000, Several other Road, Off Road and Trials Bikes, Delica Exceed
http://www.greenlaning.co.nr
#4 PostAuthor: zed1015 » Sat Mar 28, 2009 5:52 pm
Already spoke to debben's (which is where i normally get them) and they say 630 offsets are now unavailable. 530's over 17t with bearing nose are special order at £100 +. I have a 17t, 630 pitch with 5/8" offset on the wakisaki with hydraulic clutch with no clearance issues. May have to go 18t without the bearing nose as a last resort and not use my outrigger bearing.
