GEARING?
SMR610
GEARING?
#1 PostAuthor: SMR610 » Sun Mar 29, 2009 8:47 pm
Hello to one and all.
I`m after some advice on sprocket size, my GPZ1100 B1 is running 17" wheels 170/60/17 on the rear, 530 chain and an 18 tooth billet front sprocket.
What I`d like to know is what size rear sprocket should I fit to give me gearing that`s roughly the same as a standard GPZ11?
At the moment it`s a little buzzy at speed, 6000+ at 80 mph.
The front sprocket isn`t very old and was pretty expensive so I`d rather just change the rear one.
Any advice on this is appreciated.
Allan
Dark Skies
Re: GEARING?
#2 PostAuthor: Dark Skies » Sun Mar 29, 2009 9:25 pm
KZ1000-M1 CSR
Geoff Meager
#3 PostAuthor: Geoff Meager » Mon Mar 30, 2009 4:04 pm
Good sites there DS ... thanx
#4 PostAuthor: Ginger Bear » Mon Mar 30, 2009 8:40 pm
Allan,
What size rear sprocket are you running?
SMR610
#5 PostAuthor: SMR610 » Thu Apr 02, 2009 2:40 pm
Rear sprocket is 48 teeth on A GSXR rim, monoshocked with
JMC swingarm not the that should make any difference,
what rear sprocket should I fit for a better compromise
between acceleration and slightly more relaxed cruising.
Allan
#6 PostAuthor: zed1015 » Thu Apr 02, 2009 5:04 pm
I,m currently running 17 - 33 630 pitch with 17" wheels on the z1r which is close to the std z9/1000s 15-33 on 18"s. On the drouin i'm going 530 pitch which ideally wants 20 - 39/40 to get close but obviously 20t won't fit on the front so i'm going 19 - 39 or 40. A 530 rear with 39-40 teeth has roughly the same core diameter as the 630,s 33 which is really the smallest you should go before you get chain to swingarm pivot clearance issues.
Users browsing this forum: No registered users and 102 guests
