Hi guys I have a Z900 in lots of bits in the shed that will be worked on in the next five years (8 month old girl and 4 Yr old boy) what would it take to make this swing arm fit - anyone done it?
cheers
pj
ZRX12 Swing Arm - Pasc Is Selling
Hi. I've fitted lots of different arms into lots of different bikes. Could be a simple job if it's narrower at the pivot and the spindles the same dia. Just a case of some spacers and bringing the rear shock frame mounts out in line with the arms. If its wider then your looking at machining the pivot down and maybe sleeving the bearing tube etc etc. Some measurements would be helpfull.
