I'm in the process of dismantling my Z650 front forks and can't stop the damper from spinning while turning the allen head bolt at the bottom of the lower fork leg...therefore, I could really do with either borrowing or buying the adapter piece that holds the damper in place. The part no is 57001-1011.
Would appreciate it if anyone can help.
Steve
Z650 Part
forks
Pigford wrote:Whittle the end of a broom handle at about 45degs.... leave a blunt end about size of a 5pence, then ram it down the fork onto the damper.... Clamp the broom handle in a vice and undo the bolt
so thats y' all my' brushes are knackered
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
gator grip is what you need!
What you need is a Gator grip socket they are cheap and it looks like a spark plug sicket and has loads of roller like needles inside that will grip a rounded nut.
I have found these better than the proper kawasaki tool.
http://www.amazon.com/Gator-Grip-ETC-20 ... B000065CJ8
