Shim Question
Shim Question
Are Yamaha XJR 1200/1300 valve shims the same as Z900/Z1000 ones?
Re: Shim Question
No.
XJR are 25mm.
Z9/1000 are 29mm.
XJR are 25mm.
Z9/1000 are 29mm.
Re: Shim Question
Thanks for your help
needaz1100r
- ZedHead
Re: Shim Question
XS1100 and XJ1100 are the same, as are some other Yamaha XS and XJs of that age.
Also BMW K series engines and others.
Others use 29mm shims too, but I got a BMW kit for far less than a Kawasaki one, with about 5 of every size.
Mark.
Mark.
Re: Shim Question
Good info - thank you
Users browsing this forum: No registered users and 118 guests
