Spark Plugs
Camshaft cap bolts
Camshaft chain tensioner bolt
Cylinder head nuts
Cylinder head bolts
Cylinder head cover bolts
Many thanks
zed1015 wrote:Spark Plugs . - finger tighten the spark plug, then 1/2 to 2/3 turn with socket.
Pigford wrote:zed1015 wrote:Spark Plugs . - finger tighten the spark plug, then 1/2 to 2/3 turn with socket.
Hey Rob, is that with new plugs only, before the washer has been compressed?
I tend to do hand tight & then 1/4 - 1/2 turn max as scared of stripping the thread. It always seems the #4 plug is most commonly removed for checking things!
1340fxd wrote:
It is the official manual which got me going - it lists torque settings under a heading of ft-lbs and then randomly throws in settings giving in-lbs. Yes I know how to convert one to the other but the problem is identifying which is what.
