Torque settings
1340fxd
Torque settings
#1 PostAuthor: 1340fxd » Sat Apr 25, 2020 7:05 pm
I'm getting a bit confused over torque settings between the US Kawasaki service manual and Clymer as they appear to slip between inch-lbs and foot-lbs without warning! I work in Ft-Lbs so would like reassurance of the torque values for:
Spark Plugs
Camshaft cap bolts
Camshaft chain tensioner bolt
Cylinder head nuts
Cylinder head bolts
Cylinder head cover bolts
Many thanks :oops:
Dear Santa, please can I have...
compo z1r
Re: Torque settings
#2 PostAuthor: compo z1r » Sat Apr 25, 2020 7:26 pm
1 ft-lb is 12 inch-lb ie just divide by 12 to get correct setting :roll:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Re: Torque settings
#3 PostAuthor: warren3200gt » Sat Apr 25, 2020 8:37 pm
Be very careful with the cam caps and cam cover bolts. 40 odd years of heat cycles and steel bolts into ally threads makes for very easy stripping of the threads. I ignore the torque settings for those and just go with the mark one human hand feel and short spanner torque so as to not stripe the threads.
Re: Torque settings
#4 PostAuthor: zed1015 » Sat Apr 25, 2020 11:28 pm
Spark Plugs . - finger tighten the spark plug, then 1/2 to 2/3 turn with socket.
Camshaft cap bolts - 8 ft/lbs ( I just nip them up by hand)
Camshaft chain tensioner bolt - Which bolt ? . if it's the side facing 10mm for locking the plunger then as the cam cap bolts.
Cylinder head nuts _ stock studs 29 ft/lbs. ( Not 25ft/lbs as stated in early manuals)
Cylinder head bolts near the outer plugs. - 8 to 10 ft/lbs ( again I just nip them up by hand)
Cylinder head cover bolts - 8 ft/lbs but same as cam caps and head bolts
Re: Torque settings
#5 PostAuthor: Pigford » Sun Apr 26, 2020 9:12 am
zed1015 wrote:Spark Plugs . - finger tighten the spark plug, then 1/2 to 2/3 turn with socket.
Hey Rob, is that with new plugs only, before the washer has been compressed?
I tend to do hand tight & then 1/4 - 1/2 turn max as scared of stripping the thread. It always seems the #4 plug is most commonly removed for checking things!
CAT3
Re: Torque settings
#6 PostAuthor: CAT3 » Sun Apr 26, 2020 9:15 am
Guessing from your forum name you also own one of them there Yankee tractor things !! :D
I'm sure you must be used to tightening nuts & bolts up, tight, with Loctite, spring washers & wire-locked !!
However, with these marvels of the Japanese, even though they be old, they do not shake themselves to death so you should always assume the quoted torque figures are in.Lbs. until you have read the manual a second time to confirm whether it should be in.Lbs. or ft.Lbs. !! He,He :lol:
CAT3
Re: Torque settings
#7 PostAuthor: CAT3 » Sun Apr 26, 2020 9:17 am
I always do new plugs finger tight plus 1/2 turn & once used finger tight plus 1/4 maximum.
1340fxd
Re: Torque settings
#8 PostAuthor: 1340fxd » Sun Apr 26, 2020 9:45 am
Yes, 1340 FXD is because I also own a Harley - now 20 years old and having done over 100,000 miles touring Europe and while it vibrates, very little has actually fallen off along the way! My Kawasaki bikes are 1974 H2B, 1978 KZ1000 A2 and recently sold a ZX-7R P7.
It is the official manual which got me going - it lists torque settings under a heading of ft-lbs and then randomly throws in settings giving in-lbs. Yes I know how to convert one to the other but the problem is identifying which is what. :roll:
Re: Torque settings
#9 PostAuthor: chrisNI » Sun Apr 26, 2020 10:34 am
Also beware the manuals mainly have a wrong figure for cam cap bolts... methods/ figures mentioned above are safer.
Re: Torque settings
#10 PostAuthor: zed1015 » Sun Apr 26, 2020 1:48 pm
Yes! with new plugs.
If used then I just nip them up same as you 1/4 - 1/2 turn.
