Z1000A1 Float Height
#1 PostAuthor: r3sc » Mon Jun 01, 2020 7:19 pm
Hi All,
I know the best way to set the Float heights is to use the adaptor and tube to look at the fuel level but could someone tell me if there is a basic float height measurement available so that I can get them somewhere near during assembly?
I guess it’s somewhere between 22mm and 25mm from the float to the upstand on the carb body but a correct dimension would be helpful.
Thanks in advance.
Re: Z1000A1 Float Height
#2 PostAuthor: zed1015 » Mon Jun 01, 2020 7:29 pm
24mm to 26mm
#3 PostAuthor: r3sc » Mon Jun 01, 2020 7:41 pm
Thank you very much!
