z650 frame, z1 bodykit
baldrick
#1 PostAuthor: baldrick » Wed Aug 28, 2024 7:29 pm
hello, im looking at building another special.....do any of you fine knowledgeable lot know if it is possible to fit z1 bodywork to a z650 frame.
im looking at reproduction tank/ panels etc, but dont want to pull the pin if they wont fit.
thank you in advance
Re: z650 frame, z1 bodykit
#2 PostAuthor: zed1015 » Wed Aug 28, 2024 7:36 pm
They are not a direct fit and will need suitable mounts etc welding on the frame but anything will fit anything if you know how.
baldrick
#3 PostAuthor: baldrick » Thu Aug 29, 2024 5:40 pm
yes i realise that anything can be made to fit, but was looking for an easy option. thanks for replying.
j.b
#4 PostAuthor: j.b » Fri Aug 30, 2024 7:43 am
The tank is quite straightforward to fit, I put one on a z750 (this has the same frame shape around the headstock and engine) and all that was needed is to weld a piece of bar across the frame for the tank support rubbers.
baldrick
#5 PostAuthor: baldrick » Mon Sep 02, 2024 1:30 pm
ok, cool, thanks, doesnt sound like too much of an issue then.
Users browsing this forum: zapo and 61 guests
