Oil Pressure gauge.
Hey we're doing well guys.... 11 up to now
I haven't a clue about 'import duty', or if there will actually be any, but I'll confirm what I can with the suppliers.
If we can get up to 20 then I'll place the order and will have to sell the extra 5 on myself to recuperate the cost.
I will however require monies up front, either by cheque or paypal.
I consider myself to be most trustworthy and will make sure we get the best deal possible.
Regards, Will
Regards, Will
BShaw wrote:Will the order include the angles ?
Baza
Baz - They don't include the 90° elbow, nor can they supply one.
However, as soon as I get a gauge, I could source the required parts including drill & cutting tap. We could then take it in turns to do the necessary mod, then post on to each other member who bought a gauge so they can finish the job.
Will.
Is there anything wrong with these?
http://cgi.ebay.co.uk/63mm-Hydraulic-Pr ... 8001r12082
http://www.speedflowshop.co.uk/0-to-15- ... 1109-p.asp
"Set the GRINDER on it"
Gus wrote:Is there anything wrong with these?
The 63mm one off evilbay is too big, not glycerine filled and cheap and nasty but the speedflowshop one looks good. At 1-5/8ths (40mm) its spot on and looks good quality. Will still need a 90 deg angled fitting though.
Update from Marshall in the states.....
There will be VAT on top and maybe import duty too.
The one Gus found by Speedflow is the same exact gauge as the Marshall one, just different text. The needle shape, screws, everything is identical. Price is £23.32. Contact Speedflow on 0870 225 0097.
To be honest, I think this would be a better move than to order a job lot from the states. After the VAT has been added, and possible inport duty, there won't be anything between them price wise. Also, If I order from the states, I may be left with gauges I can't sell if we don't get enough takers.
Here's the Marshall one again....
and here's the Speedflow one.
See, exactly the same.
As with both, you'll still need a 90 degree fitting. There's a hydraulics company just around the corner from where I work, I know the bloke who runs it so could get a deal on the fittings.
I'm going to order one for myself and I'll let you all know of the fitting/tap required etc, unless Zed1025 beats me to it
Hope you all understand, Regards, Will.
