I will be getting my modified head back soon and have a query with the ignition side of things. I will be fitting green Dyna coils, which match the ones already fitted.
The query is how are they wired is it just a matter of splitting each wire to the coils and connecting them in the same order as if the head had single plugs.
Cheers Rob
8 plug head ignition query
Cheers for the info, could they be put in parallel as well, so that each coil (3 ohm) ignites the same plug as if they were standard. Just trying to get my head around the iginition side of things, never have liked the electrics.
Cheers Rob
Cheers Rob
Don't wire in parallel, It won't work. You will get a spark at only one coil or the other which ever offers a path of the least resistance. Also when fitting the HT leads don't put both leads from one coil just to one cylinders plugs. Say cyl's 1 and 4 should have one HT lead each from their pair of coils. That way if a coil fails you don't totally lose spark to either cylinder.
