help with Z1R exhaust gasket
bedlow1
#1 PostAuthor: bedlow1 » Sat Apr 28, 2007 11:46 am
Can somebody help! I am so near fitting a genuine exhaust to my bike, the only problem is that a important gasket seems to be no longer available. The part no. is 11009-1035, without this gasket the silencer is very loose fitting to the Box. I cant tell what this is made of to make a copy or wether it fits inside the box or over the outlet.Have any of you any ideas? its item 21 on the diagram. ta bedlow
1972 Z1 Euro Spec
1975 Z1B UK Bike
stale
#2 PostAuthor: stale » Sat Apr 28, 2007 1:29 pm
It's superseeded. Try ordering 11009-1629 or 11060-1095. They're for the 1200 Voyager.
72 H2,99 W650,72 H1C,76 KH250,75 F11,70 G4TR,78 KV75,76 KV80R,71 MT1
#3 PostAuthor: paul doran » Sat Apr 28, 2007 2:58 pm
Graham i got your pm
unfortunately my Z1R no longer has the standard exhaust fitted
Jeff Saunders
#4 PostAuthor: Jeff Saunders » Sat Apr 28, 2007 3:22 pm
If you can't find a genuine part, it will be fairly easy to either make one or adapt one from another bike. If you measure the diameter, you can match up to a few we have http://www.z1enterprises.com/SearchResu ... connecting
or give us the dimensions and we'll try and find something you can use.
The ones I see in our supplier catalogues range from 35mm internal diameter all the way to 43mm internal diameter
bedlow1
#5 PostAuthor: bedlow1 » Sat Apr 28, 2007 3:27 pm
stale and paul , many thanks have ordered a 11060-1095 as the other one was also no longer available, its quite pricey at ?16 +Vat but neccessary. have to wait a few more days now to get exhaust on.
1972 Z1 Euro Spec
1975 Z1B UK Bike
bedlow1
#6 PostAuthor: bedlow1 » Sat Apr 28, 2007 3:29 pm
thanks as well to jeff, have ordered a kawa one but will contact you if it doesnt work
1972 Z1 Euro Spec
1975 Z1B UK Bike
bedlow1
#7 PostAuthor: bedlow1 » Thu Jun 07, 2007 7:10 pm
All done now. With Marshall off and original on its so quite
1972 Z1 Euro Spec
1975 Z1B UK Bike
Padders
#8 PostAuthor: Padders » Thu Jun 07, 2007 7:16 pm
Looks a treat mate.
padders
davejames
#9 PostAuthor: davejames » Thu Jun 07, 2007 10:46 pm
Looks great, nice to see a standard exhaust and full length mudguard have survived :shock: :shock:
Ed Z1-R
#10 PostAuthor: Ed Z1-R » Fri Jun 08, 2007 7:12 am
Pukka Z1-R that :up
Mikekilbride
Re:
#11 PostAuthor: Mikekilbride » Fri Jan 08, 2021 5:35 pm
stale wrote:It's superseeded. Try ordering 11009-1629 or 11060-1095. They're for the 1200 Voyager.
Hi Do these actually fit the Z1r?
Mike
:luv This old GIT keeping the old "kawi's" rolling 5 x Z1's. 3 x 72' H2's. 2 x 73' H2's. 2 x 74 H1's. 1 x 71 H1. 1 x W1 and finally 2 x 69' A7SS :luv
KeithZ1R
Re: Re:
#12 PostAuthor: KeithZ1R » Fri Jan 08, 2021 6:15 pm
Mike
Yep I have them on two of mine :up
11060-1095
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
