help with Z1R exhaust gasket
Can somebody help! I am so near fitting a genuine exhaust to my bike, the only problem is that a important gasket seems to be no longer available. The part no. is 11009-1035, without this gasket the silencer is very loose fitting to the Box. I cant tell what this is made of to make a copy or wether it fits inside the box or over the outlet.Have any of you any ideas? its item 21 on the diagram. ta bedlow
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
- paul doran
- Jeff Saunders
If you can't find a genuine part, it will be fairly easy to either make one or adapt one from another bike. If you measure the diameter, you can match up to a few we have http://www.z1enterprises.com/SearchResu ... connecting
or give us the dimensions and we'll try and find something you can use.
The ones I see in our supplier catalogues range from 35mm internal diameter all the way to 43mm internal diameter
- Mikekilbride
- Regular Poster
Re:
stale wrote:It's superseeded. Try ordering 11009-1629 or 11060-1095. They're for the 1200 Voyager.
Hi Do these actually fit the Z1r?
Mike
This old GIT keeping the old "kawi's" rolling 5 x Z1's. 3 x 72' H2's. 2 x 73' H2's. 2 x 74 H1's. 1 x 71 H1. 1 x W1 and finally 2 x 69' A7SS
Re: Re:
Mikekilbride wrote:stale wrote:It's superseeded. Try ordering 11009-1629 or 11060-1095. They're for the 1200 Voyager.
Mike
Yep I have them on two of mine
11060-1095
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Users browsing this forum: No registered users and 159 guests
