Z1parr wrote:It's a test best carried out with your todger in each plug cap one at a time , much more accurate i find
Poor running below 2000 rpm
Checked sparks at all cylinders & all seem to be about the same strength.
Swopped leads 1 & 4 but it made no difference - problem cylinder seems to be no.1 still (header pipes takes longer to warm up on this cylinder)
Did a compression test & got readings of approx 9Bar / 130 psi across all 4 cylinders.
Still runs like a bag of pooh below 2000 rpm.
njwmct wrote:Taffus wrote:have you checked the colour of the burn with a colortune?
No I have'nt
I had a couple of problems with low speed running on the GPz1100B1 (carbed)
first issue was the idle burn was way off on all cylinders, sorted this with a colourtune.
Second issue was intermittent no 3 cylinder ending with plug fail. I thought it was the coil breaking down so ordered some more from Z1enterprises.
Whilst I waited for them to be granted asylum from customs ( they were actually kidnapped and i had pay the post office a ransom to get them released!)
I am running the dyna grey 2.2ohm coils with the standard ic igniter, originally with taylor leads but have now changed them to dyna leads
I thought I would have another look, I removed the coils to swap them over and found a white corrosion in the socket for the ht leads.
It was worse on the one on no 3 but was present in all the others. cleaned this up and bike has run fine since!
Taffus wrote:njwmct wrote:Taffus wrote:have you checked the colour of the burn with a colortune?
No I have'nt
Thanks for the tip but mine has the standard coils where the ht leads are sealed in - but I have replaced all of the plug caps - to be honest I'm starting to lose hope of ever getting it sorted (been at it for weeks!)
