Poor running below 2000 rpm
#31 PostAuthor: Pigford » Sat Sep 10, 2011 6:12 pm
Z1parr wrote:It's a test best carried out with your todger in each plug cap one at a time , much more accurate i find :up
:shock:
Z1parR
#32 PostAuthor: Z1parR » Sat Sep 10, 2011 6:14 pm
:rir :rir :rir :rir
0172 . Geoff Parr
#33 PostAuthor: z1bman » Sat Sep 10, 2011 6:25 pm
try changing the plug cap
njwmct
#34 PostAuthor: njwmct » Sat Sep 10, 2011 6:36 pm
:shock:
Are you volunteering then ? :lol:
#35 PostAuthor: PAULJAC47 » Sat Sep 10, 2011 7:00 pm
As GB said,swap 1 and four plug leads over and see if fault moves,if it does
must be the HT lead or cap!!!
njwmct
#36 PostAuthor: njwmct » Mon Sep 12, 2011 7:09 am
PAULJAC47 wrote:As GB said,swap 1 and four plug leads over and see if fault moves,if it does
Excuse my ignorance but does that work with a firing order of 1243?
#37 PostAuthor: Ginger Bear » Mon Sep 12, 2011 7:27 am
Yes, Your bike runs whats called a 'wasted spark' system. Your plugs spark at the top of every stroke, not every other. 1 & 4 spark simultaneously as do 2 & 3.
Swap 1 & 4. It's a very simple test.
# 104
Taffus
#38 PostAuthor: Taffus » Mon Sep 12, 2011 7:31 am
Ginger Bear wrote:Yes, Your bike runs whats called a 'wasted spark' system. Your plugs spark at the top of every stroke, not every other. 1 & 4 spark simultaneously as do 2 & 3.
Make sure it isn't running or you'll be doing the "Bear Dance" like in GB signature! :D
#39 PostAuthor: Ginger Bear » Mon Sep 12, 2011 9:17 am
Good point there Taffus. :ek
# 104
#40 PostAuthor: Pigford » Mon Sep 12, 2011 6:41 pm
On the contrary Taffus - You'll need to do this whilst the bike is running if you test using the Z1parr method... see top of page :??
njwmct
#41 PostAuthor: njwmct » Thu Sep 15, 2011 2:30 pm
Checked sparks at all cylinders & all seem to be about the same strength.
Swopped leads 1 & 4 but it made no difference - problem cylinder seems to be no.1 still (header pipes takes longer to warm up on this cylinder)
Did a compression test & got readings of approx 9Bar / 130 psi across all 4 cylinders.
Still runs like a bag of pooh below 2000 rpm.
Taffus
#42 PostAuthor: Taffus » Thu Sep 15, 2011 5:05 pm
have you checked the colour of the burn with a colortune?
njwmct
#43 PostAuthor: njwmct » Thu Sep 15, 2011 5:08 pm
Taffus wrote:have you checked the colour of the burn with a colortune?
No I have'nt
Taffus
#44 PostAuthor: Taffus » Thu Sep 15, 2011 5:26 pm
No I have'nt
I had a couple of problems with low speed running on the GPz1100B1 (carbed)
first issue was the idle burn was way off on all cylinders, sorted this with a colourtune.
Second issue was intermittent no 3 cylinder ending with plug fail. I thought it was the coil breaking down so ordered some more from Z1enterprises.
Whilst I waited for them to be granted asylum from customs ( they were actually kidnapped and i had pay the post office a ransom to get them released!)
I am running the dyna grey 2.2ohm coils with the standard ic igniter, originally with taylor leads but have now changed them to dyna leads
I thought I would have another look, I removed the coils to swap them over and found a white corrosion in the socket for the ht leads.
It was worse on the one on no 3 but was present in all the others. cleaned this up and bike has run fine since!
njwmct
#45 PostAuthor: njwmct » Thu Sep 15, 2011 5:59 pm
Taffus wrote:
No I have'nt
Thanks for the tip but mine has the standard coils where the ht leads are sealed in - but I have replaced all of the plug caps - to be honest I'm starting to lose hope of ever getting it sorted (been at it for weeks!)
