Who's fitted ZX9R rwu forks.
#1 PostAuthor: zed1015 » Mon Jan 30, 2012 11:56 pm
Seem to remember reading somewhere here that fitting zx9r ( c model ?) conventional rwu yokes to the Zed (900/1000 frame) are a simple bearing swap ?
Anyone got info of this + fork length measurements , wheel spindle diameter, pic's of bike etc.
Cheers,Rob.
#2 PostAuthor: Ginger Bear » Tue Jan 31, 2012 8:16 am
# 104
KWACKERZ1
zrx1100 forks
#3 PostAuthor: KWACKERZ1 » Tue Jan 31, 2012 9:40 am
rob,
ZRX1100 43MM FORKS fit with a bearing swap fork length 30.5" stem diameter TOP 25mm (BEARING 30205A) BOTTOM 28MM (BEARING 320/28X) offset 32mm. wheel spindle length 245.
#4 PostAuthor: zed1015 » Tue Jan 31, 2012 11:40 am
Ginger Bear wrote:That was Chris NI's project;
http://www.z1ownersclub.co.uk/forum/viewtopic.php?t=853
Thanks, but looks like one off yokes were used there.
Re: zrx1100 forks
#5 PostAuthor: zed1015 » Tue Jan 31, 2012 11:42 am
KWACKERZ1 wrote:rob,
Thanks! Worth a look as i do want to use a zrx muddy.
garyd
#6 PostAuthor: garyd » Tue Jan 31, 2012 12:14 pm
Bottom bearing is just a set from the ZRX...straight fit
Top, you will have to order one separately.
I'll be ordering one of these shortly... http://www.tauntontrailers.co.uk/30205a ... -679-p.asp
Funny how cheap they are if you want it for an old fart type vehicle.
Here's some quality ones. I'll be ordering one of these shortly...
http://www.bearing-king.co.uk/bearing/3 ... q-skf/2763
#7 PostAuthor: Pigford » Tue Jan 31, 2012 4:57 pm
Mr Puffin
#8 PostAuthor: Mr Puffin » Tue Jan 31, 2012 10:21 pm
Good to know :!: So how about the ZX9 ZX6 RWU trees/yokes are these just a case of changing Taper rollers and bolting up :?:
#9 PostAuthor: zed1015 » Tue Jan 31, 2012 11:10 pm
Mr Puffin wrote:Good to know :!: So how about the ZX9 ZX6 RWU trees/yokes are these just a case of changing Taper rollers and bolting up :?:
I was looking on evilbay for some chunky rwu forks and these zx9's came up -
http://www.ebay.co.uk/itm/kawasaki-zx9r ... 35b88610b7
Seller says they drop straight in the Zeds, hence the query.
Thought i'd read somewhere it was just a bearing change ?
Was hoping to keep things quick and simple on this latest project as i'm still working on the last one :lol: .
Re: zrx1100 forks
#10 PostAuthor: zed1015 » Tue Jan 31, 2012 11:14 pm
Is that fork length measurment from the fork top to the spindle center ?
KWACKERZ1
legnth
#11 PostAuthor: KWACKERZ1 » Wed Feb 01, 2012 9:41 am
Rob,
Yes it is they are basically an inch shorter than standard z900 1000 forks.
Here is some fitted.
Not in a z1000 but same bearing fitment.
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/harrisaug20111.jpg[/img]
[/img]
Standard z1000 hub in the wheel, you need to make a custom spindle, mine was made by Phil Denton but I need another one making soon. You can probably make your own.
Mr Puffin
#12 PostAuthor: Mr Puffin » Wed Feb 01, 2012 7:38 pm
Zed, I have GSXR750 forks in my project J but with the kerker in place it sit`s way too low :| Even allowing for Fork extenders like GB had made, it would still be low compared with ZRX forks.
ZX9/6 Forks Fronts seem easier to come by, so may be a good solution if they are long enough. Better still if the yokes are an easy Transplant :wink:
So if anyone has any info it would be appreciated :)
Crofty
#13 PostAuthor: Crofty » Wed Feb 01, 2012 8:06 pm
I have am in the process of fitting ZX9R forks to my second z650 (810).. Inspired by jb's nice turbo.
I was told I needed to fit a stem from the 650 into the ZX900R lower yoke. The article in practical Sportsbike with the GPZ750 getting ZX9R forks also has their lower yoke from the ZX9R getting the stem change treatment, it is quite a long stem as std.
Barry at Blue Haze engineering did this for me and is just making up the spacers to centralise the wheel now.
I picked up a cheap yoke off a CSR650, removed the stem and Barry made up a press fit bush which was welded to the stem and then pressed into the lower yoke.
I have a spare set of the ZX9R forks and front wheel spindle (like the ones fitted to ChrisNI's Z1000, with the blue air caps) and have a lower yoke coming for them soon if you were interested Rob, the forks are in very good condition with good damping, no pitting or leaks and straight.
#14 PostAuthor: Pigford » Wed Feb 01, 2012 8:29 pm
ZZR1100 forks - late 90's - same sort of thing :wink:
Approx 740mm long
I also have some Micron billet alloy padaptor plates so you can fit typical Nissin 4/6 pot calipers.... for sale
:wink:
#15 PostAuthor: chrisNI » Thu Feb 02, 2012 6:01 pm
I got yokes made up with a bit of a step and proper offset.
