Heat dissipation..(Not Kawasaki)
What is the general consensus re heat dissipation. I am building a BSA B175 engine for trials, I am using a modified Fantic 200 cyl head which has a larger finned area etc, they can get hot during trials in the warm months and they are centre plug head. On the Fantic they were black, just wondering is it best to paint or get blasted to bare ally. ?? I will be painting the barrel and using a Suzuki TS185 piston. Thanks in advance....
- paul doran
zed1015 wrote:If drilling holes in fins for the purpose of extra cooling , the holes must be of an equivalent or less diameter than the thickness of the material.
This way you end up with an equal or slightly greater than original cross sectional surface area for heat to air transfer.
you took the words right out of my mouth.
Users browsing this forum: Bing [Bot] and 42 guests
