Removing a Zed Clutch - in situ?
#1 PostAuthor: Pigford » Thu Jun 14, 2007 6:49 pm
Am I right in thinking, the only way to remove the clutch basket on me Z1000A2, is to strip the engine! I seem to remember last time I was rummaging around that bit, it looked impossible to get the clutch out without splitting the engine :!: :?:
uk kev
#2 PostAuthor: uk kev » Thu Jun 14, 2007 7:08 pm
I have just looked at the manual, and you can remove all the clutch except the housing without splitting the cases.
#3 PostAuthor: Pigford » Thu Jun 14, 2007 7:12 pm
PANTS :!:
uk kev
#4 PostAuthor: uk kev » Thu Jun 14, 2007 7:39 pm
#5 PostAuthor: Pigford » Thu Jun 14, 2007 7:44 pm
No, not you Kev, its just that you've told me what I thought, but didn't want to hear, so i'm a bit naffed of now :cry:
#6 PostAuthor: Rich » Thu Jun 14, 2007 8:35 pm
You have to split the cases to remove the basket, but you should be able to split them and leave the top end /crank undisturbed.
Garn 1
#7 PostAuthor: Garn 1 » Thu Jun 14, 2007 9:23 pm
Agree with Rich... "Cases must be split to remove the clutch basket". I have heard of a mod, where a minimum amount of alloy is removed from the cases to allow removal to be performed without splitting the cases. It is auguable whether it would be considered a necessary or desirable mod, mainly because the cases have to be split to do the mod!
It's good to know that you can leave the crank-shaft, head etc. undisturbed during this basket removal process.
RegardZ
#8 PostAuthor: Pigford » Fri Jun 15, 2007 6:28 pm
Cheers guys :cry:
Its not too bad, just snatches a bit sometimes :|
Will wait 'til it "really" needs doing :wink:
#9 PostAuthor: Rich » Fri Jun 15, 2007 7:24 pm
Pigford wrote:Cheers guys :cry:
That'll be like your brakes then :roll:
Padders
#10 PostAuthor: Padders » Fri Jun 15, 2007 7:30 pm
Saying nothing :stfu
#11 PostAuthor: Rich » Fri Jun 15, 2007 7:35 pm
PADDERS wrote:Saying nothing :stfu
Diplomat :lol:
#12 PostAuthor: Pigford » Fri Jun 15, 2007 7:47 pm
Well, yeah, I would just remove it, but like you lot said, it needs a full stip-down, so it'll have to wait :lol: :lol: :lol: :lol:
debben1
#13 PostAuthor: debben1 » Mon Jun 18, 2007 11:53 pm
Hello Pigford, sorry I missed you the other day, snatchy clutch would sound more like a broken friction plate than basket springs, have you had the pressure plate off to have a look yet, Steve
#14 PostAuthor: Pigford » Tue Jun 19, 2007 5:21 pm
Hi Steve, yeah, all plates seem OK, no ridges/burrs on basket tangs :shock:
Its when pulling away on low revs & throttle, it sometimes judders and seems to slip a bit. But clutch don't usually slip other times, like full throttle :?:
Also a bit rattly sounding when toodling along in high gears at low speed, when opening throttle (too lazy to change down) :wink:
debben1
#15 PostAuthor: debben1 » Tue Jun 19, 2007 7:34 pm
oh ok, that does sound more like the basket then. well done on your recent exposure to fame via Classic mechanics btw. I am with you on removing the front caliper, I have done the same thing to mine, 1 decent caliper offers far better braking than 2 rubbishy old calipers and looks better too :lol:
Users browsing this forum: Headspinning and 102 guests
