Z800 Cafe Chopper Fighter thing...
Royalratch
#61 PostAuthor: Royalratch » Fri Jan 06, 2012 12:16 pm
Aah - you mean on the gear shaft end of the rod that will then accept a clamp!
Gotcha.
#62 PostAuthor: zed1015 » Fri Jan 06, 2012 12:30 pm
As mentiond in my previous reply.
Unscew the short threaded bar from your link rod and screw on the R1 or R6 splined arm/clamp.
It has an integral rose joint with male thread attached so should be a simple five minute job.
Royalratch
#63 PostAuthor: Royalratch » Fri Jan 06, 2012 12:32 pm
The short threaded end does not unscrew - it's the rod itself that is threaded so I can't do what you're saying?
Hence I need a female threaded rose joint to screw onto my threaded rod end - and to that a clamp can bolt into.
Or am I wrong?
#64 PostAuthor: zed1015 » Fri Jan 06, 2012 2:13 pm
Yes! you are correct if the threaded portion is part of the link rod.
Is the link rod steel then ? as it looks like aluminium in the pic.
If it's ally i wouldn't trust the 6mm threaded portion to be strong enough.
On closer inspection of your pic though it appears to be a shouldered steel insert pressed or screwed in to the rod ?
Should be removable with little trouble if need be.
Royalratch
#65 PostAuthor: Royalratch » Fri Jan 06, 2012 2:22 pm
I can get a rose-joint quite easily right.
Cheers again!
#66 PostAuthor: zed1015 » Fri Jan 06, 2012 2:34 pm
Plenty on ebay, left or right hand thread.
I've bought quite a few from this seller.
Right hand
http://www.ebay.co.uk/itm/6mm-FEMALE-ro ... 3f122a4462
Left hand
http://www.ebay.co.uk/itm/6mm-FEMALE-ro ... 4160a23e16
P.S. Just been in the workshop and noticed that the alloy clamp from an 05 ZX10R has a rose joint attached with female threads as you require,
It has to be from an 05 model though as it appeares they switched to a male thread after that.
Royalratch
#67 PostAuthor: Royalratch » Tue Apr 10, 2012 5:54 pm
Found this on the Triumph Flickr feed...
#68 PostAuthor: Pigford » Tue Apr 10, 2012 6:23 pm
Well lush - for a "modern" bike :twisted:
Royalratch
#69 PostAuthor: Royalratch » Wed Apr 11, 2012 9:40 am
It's everything I like. retro with modern tech.
Radical forks, CNC bits but the the essence is old school.
Spokes!
Royalratch
#70 PostAuthor: Royalratch » Tue Apr 24, 2012 4:24 pm
Bit of progress made but the right kind as I now have a full on rolling bike with all the trimmings.
Disk spacers have been done so can bolt on the discs.
Headlight brackets done, intreated into the clips on - will be anodised black so they are even more incognito.
The steering lock is also on, basically it;s two screws mounted onto the bottom yoke and depending on how long
they are you can tweak the steering lock.
Gear lever linkage sorted.
And the I had the rear calliper hanger machined from scratch. I'm not sure about this as I specified a design that was
simpler and less bulky and this looks kind of okay but way chunky. Maybe it will look better in black.
Now I basically plumb it up, throw motor in and wire it up and it's ready to go. I won't do a full build and fire up,
I'll do a full dry build and no wiring to check it's all good and everything I need is done - then disassemble and
get everything off for coating / painting.
j.wilson
#71 PostAuthor: j.wilson » Tue Apr 24, 2012 4:37 pm
Great!
Hey- thats turning out like some of your sketches???
z650/1400 bonneville hybrid.
steve.w
#72 PostAuthor: steve.w » Tue Apr 24, 2012 4:38 pm
looking good mate .. u going for 1 up 4 down on the gears :?:
Royalratch
#73 PostAuthor: Royalratch » Tue Apr 24, 2012 4:43 pm
@Jwilson - yeah - looking like it. Had to take some steps to make that happen that made the job easier but shape and silhouette is super important.
As for gears - I guess whatever the gearbox attached in a GPZ750 is...?
j.wilson
#74 PostAuthor: j.wilson » Tue Apr 24, 2012 5:17 pm
I think the point "very observant Steve" is making is that you connected the gearbox actuator the wrong way up, the actuator rod should meet it below the shift shaft centre-line.
#75 PostAuthor: Pigford » Tue Apr 24, 2012 5:18 pm
The angle of the gear shift lever on the splined shaft is a bit acute - best to be as near to 90 degs as possible :!:
Users browsing this forum: Bing [Bot], trogg 41 and 62 guests
