Z1A sump capacity
nealblath
Z1A sump capacity
#1 PostAuthor: nealblath » Mon May 14, 2012 9:18 pm
It says in the Haynes book that the capacity is 4 litres of engine oil. I've put 4 litres of Motul 5100 but it is way over the sight glass at the bottom of the clutch side cover.............is this just because the engine hasn't run yet and oil filter will be empty or is this figure incorrect?
Neal
#2 PostAuthor: Pigford » Mon May 14, 2012 9:20 pm
3.6 litres (approx from memory as I can't be arsed to get up and look at me bike in the garage) --- stamped on the casing near the filler hole :wink:
nealblath
#3 PostAuthor: nealblath » Mon May 14, 2012 9:22 pm
DOHH....................thanks Pigford :D
#4 PostAuthor: zed1015 » Tue May 15, 2012 6:43 am
Used to be 4ltr but they changed it to 3.7ltr later on.
nealblath
#5 PostAuthor: nealblath » Tue May 15, 2012 7:00 am
Thanks Rob
