What plugs should I use on my Z900? Motor is 1260cc breathing via CR carbs and pretty much straight through exhaust. Dyna ignition, 3 ohm coils and Taylor leads.
Do I stick to those recommended for stock or would you recommend different?
Road use only.
Spark plug recommendation non stock Z900 motor
I've been using DENSO Iridium in my Zeds for the last couple years - no probs..... me Z1000A2 has been sprinted, long runs to & from York, short trips to & from Work, etc...... still on same set - slightly colder/harder grade than standard..... IW-27
http://www.densoiridium.com/spconstruction.php
Not cheap, but I'd recommend them
- london calling
