What Do You Think This Is
carpy
#1 PostAuthor: carpy » Mon Jun 18, 2012 11:03 pm
Pictures of debris removed from Z1000-A2 sump. Any ideas of what they are? 5p shown for scale only :D Pic 3 shows lots of metal particles in the sludge.
#2 PostAuthor: zed1015 » Tue Jun 19, 2012 12:00 am
1. There's some bits of clutch plate.
2. Also one of those rubber dampers that sit at the ends of the camchain idler pivots
3. And what looks like bits of rubber 'O' ring , Maybe cam tunnel 'O' ring ?
jimmock
#3 PostAuthor: jimmock » Tue Jun 19, 2012 2:39 am
Looks feckin serious to me!!!!!
Jimmock. :wnkr
I hate people I don't like !
gray
#4 PostAuthor: gray » Tue Jun 19, 2012 9:13 pm
fairly chewed up bits there.but it's not all bad
the 5p looks reusable though. some duffer must have dropped it in while filling up with oil.
( pardon the note of levity)
gray
#5 PostAuthor: chrisNI » Tue Jun 19, 2012 10:30 pm
Damper block looks fairly fresh too...
carpy
#6 PostAuthor: carpy » Tue Jun 19, 2012 10:58 pm
Spoke to my mate in the states (previous owner) and he said prior to his ownership it had had a catastrophic engine failure and been fixed hence 900 barrels on z1000 crankcases. He had never took the sump off so those bits could have been in there for years. Going to take the camshafts out so I can check the camchain guides, just in case. He told me it was a z1b head, I don't know but it's got a z1000 camchain idler fitted with bits of the damper rubbers missing - good grief
gray
#7 PostAuthor: gray » Wed Jun 20, 2012 8:22 pm
Who suffers a catastrophic engine failure and doesn't drop the sump?
D'oh!
gray
#8 PostAuthor: zed1015 » Wed Jun 20, 2012 8:50 pm
gray wrote:Who suffers a catastrophic engine failure and doesn't drop the sump?
D'oh!
Probably the same bloke who left 6 fag ends, 4 circlips, 3 teflon buttons and a 6mm bolt in the bottom of the one i've just pulled apart :lol:
Taffus
#9 PostAuthor: Taffus » Wed Jun 20, 2012 9:09 pm
D'oh!
can I have my buttons back :?:
Keefleaf
#10 PostAuthor: Keefleaf » Wed Jun 20, 2012 10:09 pm
I found aBeetle I one sump,complete ,( VW engine management system ? )
Also found a Moth in another ?
Pictures on a disc somewhere
Users browsing this forum: Google [Bot] and 66 guests
