Slipping clutch
Robw
Slipping clutch
#1 PostAuthor: Robw » Sun Jul 08, 2012 7:49 pm
Hi All, just returned from a great weekend at Mallory and my clutch slips at 6500rpm. The clutch plates etc are new, but the engine is tuned. What's the best solution, I thought about fitting stronger springs? If so where can I get them from.
Cheers Rob
#2 PostAuthor: PAULJAC47 » Sun Jul 08, 2012 8:14 pm
What bike is it? what oil are you using?
#3 PostAuthor: Al » Sun Jul 08, 2012 8:25 pm
Debbens do the 10 or 15% uprated springs, i forget which.
You can also put in another plain plate to preload it.
Which way round have you put the plates.
Genuine ones go in a particular way round.
Non original ones can also be helped a little by careful orientation.
Is the clutch basket baggy on its centre sleeve?
As paul says which type of oil?
Take it thats its' the 1000R!
Robw
#4 PostAuthor: Robw » Sun Jul 08, 2012 8:30 pm
Hi, it is a 1170 Eddie lawson rep with gas flowed, big valve etc head and I am using 10/40 semi synthetic oil.
Rob
#5 PostAuthor: zed1015 » Sun Jul 08, 2012 8:37 pm
Get mine off ebay for around a tenner a set depending on model.
Here's some EBC , around 10% stronger.
http://www.ebay.co.uk/itm/Kawasaki-Z-11 ... 20bec737a2
Robw
#6 PostAuthor: Robw » Sun Jul 08, 2012 9:00 pm
I fitted a genuine new clutch basket and plates only a couple of 1000 miles ago, so I hope it's alright. I will strip it down during the week to check to see if anything is baggy.
Rob
Jerry
President
President
#7 PostAuthor: Jerry » Mon Jul 09, 2012 4:31 pm
Semi synthetic oil has the same effect as fully synthetic on the clutch - when I tried it, the clutch didn't actually slip as such, but it was noticeable on gear changes that it sort of slipped into the next gear, no matter how fast the lever went out. Personally, I'd try an oil and filter change before getting onto the expensive stuff.
SteveZ
Stronger clutch springs.
#8 PostAuthor: SteveZ » Thu Jul 12, 2012 6:36 pm
As a warning-I fitted stronger clutch springs to my Z1000 and the clutch pushrod and release bearing welded themselves to the inside of the mainshaft!Big job.Debben supply a needle roller clutch lifter which is well worth the asking price.
#9 PostAuthor: Pigford » Thu Jul 12, 2012 7:04 pm
Do what I did when my clutch started slipping.... fit a "lock-up" clutch :wink:
Bruce Sexton
#10 PostAuthor: Bruce Sexton » Fri Jul 13, 2012 12:13 pm
Just an off topic thought but does it do it if you go anwere else or is it just mallory? :D
sorry its Friday afternoon.
Bruce
Robw
#11 PostAuthor: Robw » Fri Jul 13, 2012 3:35 pm
Hi, it has gone occasionally else where ,especially when I am acclerating fast, but mainly it has been going when thrashing it out of the Devils elbow. Mainly, I think due to the bike being ridden like I stole it :)
Rob
