Newbie with Swingarm question - Metchamex?
sled
#1 PostAuthor: sled » Tue Jul 17, 2012 12:17 am
Gday
I have been long time looker on this forum You brits do the most awsome builds! I bough myself a kz900 from the states about 6 months ago been cleaning it up, sprad panels tank etc, slowly working through some dodgy maintenance. thats another story.
This build appeals to the style i am after, does any one know if this is a metmachex swingarm?? i have been looking on the net and can't find much info or pictures for z900. I like the small brace, and want to fit a 160 tyre on 4.00 - 4.5 rims any one know if this is possible? How to people stabilise the drum brake?
http://www.z1ownersclub.co.uk/forum/vie ... &start=105
Any help is appreciated cheers Jason
Charlie
#2 PostAuthor: Charlie » Tue Jul 17, 2012 8:52 am
It could well be. I have a low brace Metmachex that looks like that for my Z650. The main difference being that my adjuster centre is black and not gold.I would add a photo, but neither the bike nor the arm are at home at the moment.
I dont think there are too many low brace arms about, almost all the one's I see are deep brace.
sled
#3 PostAuthor: sled » Tue Jul 17, 2012 11:30 am
Thanks Charlie
What size wheel you running? Drum brakes?
Charlie
#4 PostAuthor: Charlie » Tue Jul 17, 2012 3:22 pm
No mine is a disc rear. The only difference in swingarm though is one has a torque arm fixing on the top (disc type) and one on the bottom. It's easy to swap em over if you can access a welder.
I am on stock size 120/90 x 18 rear at the moment but I do want to go to 17" front and rear.
I have just too many other jobs going at the moment to add another to the list. It may have to wait until winter to do that. I am undecided which way to go. the easy way would be to get some spoked hubs and build into 17" Supermoto type rims....but I prefer alloys and I need to check front clearances anyway to find out if I can run a 110/70 or a 120/60 or 70x 17 front with stock forks or if I need to change those as well.....hence the job being on hold probably until winter. :)
Dodgy Z1B
#5 PostAuthor: Dodgy Z1B » Tue Jul 17, 2012 7:34 pm
Think its a JMC as far as Im aware metachex adjusters are different.
samspoons
#6 PostAuthor: samspoons » Tue Jul 17, 2012 9:34 pm
Did Davida do that type as well
GUYZED
#7 PostAuthor: GUYZED » Tue Jul 17, 2012 9:37 pm
samspoons wrote:Did Davida do that type as well
Thats what i thought it was...i could be wrong though.
#449
Z1000A2 Z650B1
#8 PostAuthor: z1bman » Tue Jul 17, 2012 9:50 pm
the way the eccentric adjusters are secured it does look like a davida but i cannot see any wheel spindle or wheel nut so how is the wheel secured ?
#9 PostAuthor: zed1015 » Tue Jul 17, 2012 10:06 pm
z1bman wrote:the way the eccentric adjusters are secured it does look like a davida but i cannot see any wheel spindle or wheel nut so how is the wheel secured ?
Caphead bolts are countersunk into the eccentrics.
sled
#10 PostAuthor: sled » Wed Jul 18, 2012 1:45 am
Never heard of Davida. I assume this is past tense as looking at their website they sell clothing?
Anyone have any ideas on the metchmex
thanks for the comments
GUYZED
#11 PostAuthor: GUYZED » Wed Jul 18, 2012 5:17 am
This any good to you Jason :?:
http://www.metmachex.net/p0_0_0.htm
#449
Z1000A2 Z650B1
steve.w
#12 PostAuthor: steve.w » Wed Jul 18, 2012 5:01 pm
its a metamex... bgb has one hes taking out off a mk 11 :D
Charlie
#13 PostAuthor: Charlie » Wed Jul 18, 2012 5:06 pm
They are all much of a muchness anyway. Metmachex, JMC. etc
Davida's tend to be a bit more rare and I haven't seen a braced aluminium coloured one, only black - but that's not to say they never existed.
sled
#14 PostAuthor: sled » Wed Jul 18, 2012 9:19 pm
thanks for replies
O have looked at the Mechamex site on and off for many years was looking at one for my YPVS 350 a while ago. There is little info on the site and the z1000 picture is heavy braced. i have emailed them waiting on reply. There is little info on the site such as dimensions? does it use needle bearings? can it fit a 160 tyre? do you use standard wheel spacers? If it is the one in the thread then that would answer a few of these Qs.
There is also http://www.win-pmc.com/draft/sa.html but think mechas a little nicer.
steve.w
#15 PostAuthor: steve.w » Thu Jul 19, 2012 9:37 am
metamex take up to a 160 tyre max :wink:
