GB's 'Period' modded Z1000A2 with 'Toast Racks'
#46 PostAuthor: zed1015 » Thu Sep 13, 2012 9:01 pm
Looks like you pulled it apart just in time.
Why is there always a piece of orange gasket sealant on the oil pickup even when there's no evidence of it being used on any of the joints :lol:
#47 PostAuthor: Ginger Bear » Thu Sep 13, 2012 9:20 pm
Rob, plenty of evidence of the orange goo....... All over the clutch cover, red stuff too! :roll:
I am amazed the cams are in such good nick, after seeing the state of that gauze.
# 104
mikey
#48 PostAuthor: mikey » Mon Sep 17, 2012 5:55 pm
Here you are steve a pic of my Zthou when i first got it
with the actual toast racks that you have now
#49 PostAuthor: Ginger Bear » Mon Sep 17, 2012 6:42 pm
Bloody hell Mikey, that's what I'm planning.............
.................... Red paint, white wheels, JMC swinger & those toast racks. :shock: :shock:
# 104
Mark Tiller
#50 PostAuthor: Mark Tiller » Mon Sep 17, 2012 7:09 pm
another one of those special brown Harris exhausts
07962421462
#51 PostAuthor: Ginger Bear » Mon Sep 17, 2012 7:23 pm
Deffo WON'T be having a Harris.............
.......................... Alfa 4-1 for me. :sou
# 104
mikey
#52 PostAuthor: mikey » Mon Sep 17, 2012 9:19 pm
But im glad to say it looks like this now
sorry steve thats hijacking your thread a bit there
#53 PostAuthor: Ginger Bear » Mon Sep 17, 2012 9:23 pm
No problem Mikey..............
........................ Those tank badges look perfectly positioned. :wink:
# 104
complete zedness
#54 PostAuthor: complete zedness » Mon Sep 17, 2012 10:33 pm
Just read the whole thread, superb Steve. Keep at it :up
mikey
#55 PostAuthor: mikey » Tue Sep 18, 2012 3:42 pm
Ginger Bear wrote:No problem Mikey..............
Thats cuz your eyesight and measuring skills are better than mine :D
#56 PostAuthor: Ginger Bear » Tue Sep 18, 2012 8:02 pm
OK, some progress.......
Split the cases last week, degreased them, then jet washed them.
Spent a while bead blasting them, to what I thought was a reasonable standard....................
......................... After looking at Bongo's vapour blasted cases at the weekend, I realised, I'd never be happy with the finish I'd achieved, but didn't want to spend a chunk of dosh (I'm trying to keep this project as low budget as poss) :roll:
So they were back in the blast cabinet, with some 120 grit Aluminium oxide, that really did knock off all the shit, then I emptied all that out & put the glass beads back in & went over the cases again. Gotta say, I'm quite happy with them now. :D
One benefit for me, over vapour blasting is that I only do the outsides, I know vapour blasting isn't meant to remove any material & is supposed to be fine on bearing/mating surfaces, but after cleaning these up with some fine wire wool, you can still see the original machining marks. :lon
Spent most of today, washing the cases & oilways, used a little rag on a wire, as per Rob (Zed1015)..... Thanks, Rob. :wink: Re-Tapped all the threads too.
Steadied cases & fitted a replacement crank, as the original has a suspect taper. Got to say thankyou to young Mr Coldsummer for helping me out with a lot of replacement engine parts.
That's enough for tonight! :wink:
# 104
coldsummer
#57 PostAuthor: coldsummer » Tue Sep 18, 2012 9:07 pm
Oooh this is starting to get interesting now :D Nice job on those cases Steve, very impressive.
#58 PostAuthor: paul doran » Wed Sep 19, 2012 9:21 am
cases look good Steve
I have finally got My Sods Blast set up going and blasted a cyclinder head for a Fellow Club Member and it turned out fine
I am currently building a room just for this purpose
so with a machine shop and blasting set up I can do nearly everything in house
#59 PostAuthor: Ginger Bear » Thu Sep 20, 2012 7:34 pm
Before joining the two cases, I gave the end of the kickstart shaft a little clean in the bead blast cabinet. Double wrapped it first in a couple of poly bags, save's taking it all apart.
I've seen plenty of gleaming bike's with freshly re-chromed kickstarts, let down by a shitty looking shaft.:?? (Jimmock.... No need to make any 'shaft' observations. ):roll:
After coating the mating faces with Kawabond, I've bolted 'em all together with some freshly re-zinced fasteners from Mikey.
Hopefully I'll get the barrels on & get it in the frame over the weekend. :lon :lon
# 104
ollie
#60 PostAuthor: ollie » Sat Sep 22, 2012 6:03 pm
looking great Steve ,casings look really good mate ,i wish i had bought it now :roll:
keep those pics coming ,i am really enjoying seeing this project coming back to life . :wink: :hur2
Users browsing this forum: No registered users and 192 guests
