I need to source brake lines for the Lawson which is now sporting AP calipers. Looking at others that have these the lines seem to have a straight connection in to the calipers and no obvious banjo fitting yet reviewing both Earls and Venhill sites I cant see this type of what I assume to be male connector.
Can anyone point me in the right direction?
Brake hoses / AP calipers
martinz1000r
Re: Brake hoses / AP calipers
martinz1000r wrote:I need to source brake lines for the Lawson which is now sporting AP calipers. Looking at others that have these the lines seem to have a straight connection in to the calipers and no obvious banjo fitting yet reviewing both Earls and Venhill sites I cant see this type of what I assume to be male connector.
I went straight to Goodrich direct, they made mine up on the Saxon.
martinz1000r
I got mine from B&C in Potterhanworth Lincs.
I made pattern lengths from Co-ax Cable as its about the same Dia and flexibility then took them over to them with the callipers and Master cylinders to ensure the correct threads - as I wasn't sure about the standardisation of threads !!
I got a full set and Hydraulic clutch lines made "while you wait" there HEL hoses.
Pics are on my thread - Page 2 - if thats any help to you.
regards
Howie
regards
Howie
martinz1000r wrote:that's exactly what I'm after but the Goodridge site is amazingly complex. Might try ringing them.
...and that's exactly what I did, ring them.
Like "Mr Oink" says, they're very helpful
- steve bowdler
