Brake hoses / AP calipers
martinz1000r
#1 PostAuthor: martinz1000r » Tue Jan 15, 2013 11:57 am
I need to source brake lines for the Lawson which is now sporting AP calipers. Looking at others that have these the lines seem to have a straight connection in to the calipers and no obvious banjo fitting yet reviewing both Earls and Venhill sites I cant see this type of what I assume to be male connector.
Can anyone point me in the right direction?
Big Fluff
Re: Brake hoses / AP calipers
#2 PostAuthor: Big Fluff » Tue Jan 15, 2013 1:01 pm
martinz1000r wrote:I need to source brake lines for the Lawson which is now sporting AP calipers. Looking at others that have these the lines seem to have a straight connection in to the calipers and no obvious banjo fitting yet reviewing both Earls and Venhill sites I cant see this type of what I assume to be male connector.
I went straight to Goodrich direct, they made mine up on the Saxon.
martinz1000r
#3 PostAuthor: martinz1000r » Tue Jan 15, 2013 1:40 pm
that's exactly what I'm after but the Goodridge site is amazingly complex. Might try ringing them.
#4 PostAuthor: Pigford » Tue Jan 15, 2013 3:47 pm
martinz1000r wrote:that's exactly what I'm after but the Goodridge site is amazingly complex. Might try ringing them.
Goodridge are VERY helpful - they sorted out all my fittings when I did the plumbing on my MKII Sprinter that was "dry-blocked" :wink:
HowieD
#5 PostAuthor: HowieD » Tue Jan 15, 2013 8:48 pm
I got mine from B&C in Potterhanworth Lincs.
I made pattern lengths from Co-ax Cable as its about the same Dia and flexibility then took them over to them with the callipers and Master cylinders to ensure the correct threads - as I wasn't sure about the standardisation of threads !!
I got a full set and Hydraulic clutch lines made "while you wait" there HEL hoses.
Pics are on my thread - Page 2 - if thats any help to you.
regards
Howie
Big Fluff
#6 PostAuthor: Big Fluff » Tue Jan 15, 2013 8:49 pm
...and that's exactly what I did, ring them.
Like "Mr Oink" says, they're very helpful :D
steve bowdler
#7 PostAuthor: steve bowdler » Tue Jan 15, 2013 9:28 pm
Like "Mr Oink" says, they're very helpful :D[/quote]
Bit impersonal :lol: :lol:
Robw
#8 PostAuthor: Robw » Tue Jan 15, 2013 9:54 pm
I spoke to a lovely lady at Goodridge who knew the adapter measurements from memory.i have just checked my notebook and the thread is 3/8 x 24 unf and the banjo adapter is 305-03-31.
Check before you buy though.
Rob
