Starter clutch
Z1B Alan
Starter clutch
#1 PostAuthor: Z1B Alan » Tue Jan 29, 2013 8:23 pm
I need to investigate my Z1B starter clutch and therefor require a bolt to remove the rotor. I am aware the steering stem and rear spindle bolts fit but these are both chromed and so I don't want to damage them. I believe the bolt is m16 but I dont know the pitch can anyone give me the correct pitch and any tips for the removal of the rotor.
Alan
Keefleaf
#2 PostAuthor: Keefleaf » Tue Jan 29, 2013 9:04 pm
Try using the Kawasaki bolts but put a piece of wood over the end before you hit it.
P.S. the Std bolts are tapered so you don't F'k the thread.
Z1parR
#3 PostAuthor: Z1parR » Tue Jan 29, 2013 9:14 pm
I could have a non too pretty steering stem bolt dropped off in Ewloe that you can use Alan ?
0172 . Geoff Parr
KeithZ1R
#4 PostAuthor: KeithZ1R » Tue Jan 29, 2013 9:26 pm
if you use the stem bolt put a suitably sized ball bearing against the shaft end first and forget about whacking it lock everything up and use a big lever on the socket
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#5 PostAuthor: zed1015 » Tue Jan 29, 2013 10:02 pm
Yes ! don't whack the extractor bolt, it can weaken the rotors magnetism.
KeithZ1R
#6 PostAuthor: KeithZ1R » Tue Jan 29, 2013 10:06 pm
and if your really unlucky the feckin things will fall apart :oops:
Keith
:bop :gom
mistaken.
zmaxmotorsports
#7 PostAuthor: zmaxmotorsports » Wed Jan 30, 2013 3:53 am
KeithZ1R wrote:if you use the stem bolt put a suitably sized ball bearing against the shaft end first and forget about whacking it lock everything up and use a big lever on the socket
Exactly :)
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
Users browsing this forum: No registered users and 94 guests
