Hi, What's the best solution, how much does Phillpotts charge per set? What are the repro ones like? Are there any differences in the tubes between the models? (72 forks)
Thanks for any input.
Fork tubes. Get plated or get new?
MalmoJoe, The Z1, Z1A, Z1B and Z900-A4 have the same fork tubes.
Z1000 and later have the small spacers and valve burnished in, and are not as easy to get plated and reground.
These Z1 repro tubes are great and do work out cheaper than having the originals plated and re-ground. I would recommend them any time.
I do believe the repro tubes are probably made by the original contractor that initially supplied them to Kawasaki.
These are really good quality, used them on my last resto. http://www.ebay.co.uk/itm/Front-Fork-St ... 460d2f706e
malmojoe
