tyres
tyres
would any one be able to tell me what size tyre will go in a metmachex swing arm on z900.(width wise)i have a 120 in now ,but whant to put maybe a 160 in,any help would be more than i got now.
- london calling
Re: tyres
hillbilly wrote:would any one be able to tell me what size tyre will go in a metmachex swing arm on z900.(width wise)i have a 120 in now ,but whant to put maybe a 160 in,any help would be more than i got now.
Does anyone know the answer to this question as I will be having my wheels built up this week hopefully. I will have a 3.5 rim on the back and thinking about either 150 or 160 tyre ?
LE to JOG on a z900
P.U.M.
P.U.M.
Most I got without offset front sprocket with safe clearance was a 140x18, on a JMC monoshock conversion
swinger that was designed to fit standard wheel and swingarm pivot for '76 z900
So assuming the Metmachex is same width points all round to standard z900,
you'd be safe with a 140...
But most you could go is 180mm with 5/8th offset front sprocket (from Debbens / Z-Power)
with a modded swinger.
- london calling
Jay1969 wrote:Most I got without offset front sprocket with safe clearance was a 140x18, on a JMC monoshock conversion
Wheels I had front and rear were CMA 3 spoke cast ally made to order rims
and were 4" wide on the rear, with the 140mm, forgot to add
For a 180 width, not that you want one, but just for reference: 5.5" rim.
Users browsing this forum: Google [Bot] and 34 guests
