tyres
hillbilly
tyres
#1 PostAuthor: hillbilly » Sat Jun 28, 2008 8:48 am
would any one be able to tell me what size tyre will go in a metmachex swing arm on z900.(width wise)i have a 120 in now ,but whant to put maybe a 160 in,any help would be more than i got now. :??
london calling
#2 PostAuthor: london calling » Sat Jun 28, 2008 4:02 pm
Depends on the width of your wheel.
More harm than good with over-tyring ?? a narrow rim
Jack
hillbilly
#3 PostAuthor: hillbilly » Sat Jun 28, 2008 8:00 pm
its got a disc on back,think off a z1000,normal size for them models i suppose.
Jumbo
Re: tyres
#4 PostAuthor: Jumbo » Sat Jun 29, 2013 8:59 pm
hillbilly wrote:would any one be able to tell me what size tyre will go in a metmachex swing arm on z900.(width wise)i have a 120 in now ,but whant to put maybe a 160 in,any help would be more than i got now. :??
Does anyone know the answer to this question as I will be having my wheels built up this week hopefully. I will have a 3.5 rim on the back and thinking about either 150 or 160 tyre ?
LE to JOG on a z900
P.U.M.
Jay1969
#5 PostAuthor: Jay1969 » Sat Jun 29, 2013 9:37 pm
Most I got without offset front sprocket with safe clearance was a 140x18, on a JMC monoshock conversion
swinger that was designed to fit standard wheel and swingarm pivot for '76 z900
So assuming the Metmachex is same width points all round to standard z900,
you'd be safe with a 140...
But most you could go is 180mm with 5/8th offset front sprocket (from Debbens / Z-Power)
with a modded swinger.
london calling
#6 PostAuthor: london calling » Sun Jun 30, 2013 5:33 am
3.5" rim width is fine for a 140/70 x 18 rear tyre.
You might get a 150 on there :??
Pointless over-tyreing ?? a rim as you usually get less contact patch with the tyre and often affects handing.
Jack
Jay1969
#7 PostAuthor: Jay1969 » Sun Jun 30, 2013 7:48 pm
Jay1969 wrote:Most I got without offset front sprocket with safe clearance was a 140x18, on a JMC monoshock conversion
Wheels I had front and rear were CMA 3 spoke cast ally made to order rims
and were 4" wide on the rear, with the 140mm, forgot to add :wink:
For a 180 width, not that you want one, but just for reference: 5.5" rim.
