Cam covers
harrythemagnum
Cam covers
#1 PostAuthor: harrythemagnum » Tue Jul 16, 2013 9:14 pm
Will be looking for an engine soon for a MkII project, if I cant find a proper MkII motor can I make an older engine look like one by changing the covers?
:roll:
What a wonderful philosophy you have,
#2 PostAuthor: zed1015 » Tue Jul 16, 2013 9:24 pm
YES! Except the alt cover as the earlier engine has a smaller alt taper and the associated cover is smooth apart from the DOHC logo.
The later mk2 has a larger taper and different design alt with a cover that has ribs/finning.
Fitting a mk2/st crank would solve that problem and allow the correct alt and cover to be fitted.
harrythemagnum
#3 PostAuthor: harrythemagnum » Tue Jul 16, 2013 9:39 pm
Ta
:P
#4 PostAuthor: Ginger Bear » Thu Jul 18, 2013 6:59 am
If you do fit a MK ll crank, you must change the cam wheels as well.
MK ll runs 32t crank & 16t cams. Earlier motor runs 30t crank & 15t cams. They won't 'mix & match' :shock: :press
# 104
Z1parR
#5 PostAuthor: Z1parR » Thu Jul 18, 2013 6:01 pm
I've a 'spare' MK11 crank , rotor , alt casing and possibly cams .
Pm me if you can use them :D
0172 . Geoff Parr
