Carb identification please
garyd
#1 PostAuthor: garyd » Sun Aug 11, 2013 8:13 pm
I'll be adding photos a little later but just removed the carbs from my z1000 LTD ( MKII engine) and the 2nd carb from the left has some sort of acelertor punp.
It looks like it's meant to be there but not seen this before.
Is this STD on an import Ltd? or from another model.
thanks for any help
#2 PostAuthor: zed1015 » Sun Aug 11, 2013 8:35 pm
Vm28mm carbs with accelerator pump.
Usa got them and we didn't.
Very nice and the best type of the lot.
Wanna sell :D
garyd
#3 PostAuthor: garyd » Sun Aug 11, 2013 8:41 pm
Oddly enough...yes.
Was thinking about a tart up over winter and thought about going for 29mm.
Only really took them off to give them a bit of a clean.
I thought the pumps were only useful for carbs set up for big engines and needed a bit of help on WOT.
#4 PostAuthor: zed1015 » Sun Aug 11, 2013 10:33 pm
No. Everytime you open the throttle they squirt.
They react quicker that the pilot and main jet.
Sort of fills in the gap and gives faster throttle response.
Probably better carbs than the 29's unless you are going with an overbore,fast cams and flowed head for outright top speed.
All this fitting of 29's on relatively mild road motors is crap, I would take your 28 pumpers everytime.
You can easily pull 160mph on 28's and keep the lowdown response.
Z903
#5 PostAuthor: Z903 » Mon Aug 12, 2013 8:30 am
Bugger! These were on my modded Z1-A when I got it, I was told they were crap so I yanked 'em off and put original Z1 28's on. :(
Gus
#6 PostAuthor: Gus » Mon Aug 12, 2013 11:05 am
You just keep learning Z stuff every day.
So the big question is "what are they worth"?
"Set the GRINDER on it"
garyd
#7 PostAuthor: garyd » Mon Aug 12, 2013 5:02 pm
Only as much as someone will pay :??
Not sure I want to flog em now.....but then I always have been a sucker for cash....and I am a bit potless at the moment. :cry:
Gus
#8 PostAuthor: Gus » Mon Aug 12, 2013 6:21 pm
garyd wrote:I am a bit potless at the moment. :cry:
Took the words right out of my mouth :lol: :lol: :lol:
Z1parR
#9 PostAuthor: Z1parR » Mon Aug 12, 2013 6:39 pm
Gus wrote:You just keep learning Z stuff every day.
My 28mm pumpers are worth a hoooge amount , now :lol:
0172 . Geoff Parr
garyd
#10 PostAuthor: garyd » Mon Aug 12, 2013 7:23 pm
Well, I've been advised these are about the best ones I can get for a good road bike so I'd be foolish to part with them.
I appreciate your honesty guys.
Gary
malmojoe
#11 PostAuthor: malmojoe » Sun Aug 18, 2013 9:03 pm
checked a set I've got today and they are the same. tidy. :D
Do you think they would be better than 34CV carbs like on the R1 for a 900 with popi cams and a kerker?
#12 PostAuthor: zed1015 » Mon Aug 19, 2013 7:58 am
Should mention that these pumper carbs came in 26mm as well but only for a short production run.
They are identified ( other than by measuring the venturi ) by the extra diaphragm on the underside next to the accelerator pump.
The 28's don't have the extra diaphragm but just the unfinished casting.
The diaphragm works of the inlet vacuum and prevents the accelerator pump from working unless the engine is running to prevent flooding.
The 28's were a replacement for the 26's which didn't perform as well as Kawasaki intended.
#13 PostAuthor: zed1015 » Mon Aug 19, 2013 7:59 am
malmojoe wrote:checked a set I've got today and they are the same. tidy. :D
I would favour the slide carbs over the cv's .
Users browsing this forum: No registered users and 141 guests
