Oil light comes up on hard excelleration
johny brando
#1 PostAuthor: johny brando » Mon Sep 30, 2013 12:05 am
1976 Z900 ( but the Oil pump could be earlier though for all I know ? )
Hi.I'm knew to this Forum (but had 900 Kawas since 1975 ) my oil light comes up under hard excelleration & goes out when I roll off the power. I hear the sump gate fix is not worthy of trying & deemed a waste of time now ? I'm going to put an Oil gauge off the main Oil gallery to see what I've got & I expect it to be a little low... as I'm running an oil cooler & if it close to 3psi at 4000 rpms with hot oil well all's OK then & I'll then know it's the pressure switch ... but if it's less than 3psi...... I'll disconnect the cooler & try again & if it's still low then , well I guess I'll have to check all the Oil pump internals & clearances. I'd just like to know if any one else has had this issue & what you found to be the problem ....as many heads make light work aye ... I appreciate any valid imput please ?
Thanks Guys, :lol:
johny brando
Re: Oil light comes up on hard excelleration
#2 PostAuthor: johny brando » Mon Sep 30, 2013 6:16 am
johny brando wrote:1976 Z900 ( but the Oil pump could be earlier though for all I know ? )
Thanks Guys, :lol:
WOW.....I've FOUND THE ANSWER on this Awsome Forum of yours !
One of your Guys...BIG FLUFF your a legend !!!!
I was trolling through the forum & found his reply post from a while back. I'd heard about this Hole drilling mod but dismissed it thinking ....that sounds dodgy ! but HEY it's for real ...his factory bullentin is a winner ...WELL DONE & thankyou Big Fluff.
#3 PostAuthor: zed1015 » Mon Sep 30, 2013 7:21 am
The oil pan gate is not a waste of time and a good and easy mod to have if you ride with a heavy wrist or have a tuned motor.
I fit one to all of mine.
Big Fluff
#4 PostAuthor: Big Fluff » Mon Sep 30, 2013 10:24 am
Glad to be of assistance, and like Rob (Zed1015) says, a worthwhile mod on any sump.
Cheers, Will
snotie1965
#5 PostAuthor: snotie1965 » Mon Sep 30, 2013 12:31 pm
Big Fluff wrote:Glad to be of assistance, and like Rob (Zed1015) says, a worthwhile mod on any sump.
Cheers, Will
Should the mod be done to a gpz11 ut motor ? if so could you tell me where it is on the forum ? cheers Andy .....
Taffus
#6 PostAuthor: Taffus » Mon Sep 30, 2013 12:40 pm
Cheers, Will
Depends
http://www.debben.co.uk/oilpangate.html
snotie1965
#7 PostAuthor: snotie1965 » Mon Sep 30, 2013 4:01 pm
Taffus wrote:
Cheers, Will
Depends
What does it depend on ? sorry if i sound a retard !!!
sanderz
#8 PostAuthor: sanderz » Mon Sep 30, 2013 4:44 pm
Hope this helps if you go ahead with the mod - well worth it in my opinion
Wots up DOHC
Taffus
#9 PostAuthor: Taffus » Mon Sep 30, 2013 4:58 pm
snotie1965 wrote:
Taffus wrote:
Cheers, Will
Depends
Which year I am guessing, it's a long time since I have seen the sump on the unitrac so don't know if there is an internal change
snotie1965
#10 PostAuthor: snotie1965 » Mon Sep 30, 2013 7:20 pm
Taffus wrote:
snotie1965 wrote:
Taffus wrote:
Cheers, Will
Depends
It is a 1983 standard motor, i have just had the sump off to fix slight oil seep and checked oil pump filter ,but i did not know about this mod then :(
hanskloss
#11 PostAuthor: hanskloss » Tue Oct 01, 2013 9:13 pm
had the same problem, easily sorted:
http://www.z1ownersclub.co.uk/forum/vie ... highlight=
Users browsing this forum: Bing [Bot] and 118 guests
