Unitrac cams into gpz1100b1
BRIAN S
#1 PostAuthor: BRIAN S » Wed Oct 02, 2013 8:08 pm
Going to be giving my gpz1100b1 a top end rebuild soon
and was thinking of fitting the cams from a unitrac to give a bit of a power boost.at the same time has anyone done this,what are the pros and cons?
do I need anything other than the cams? I know the uni has under bucket shims
but what are the chances of it spitting a shim if I stick with my over bucket shims? any advice/info would be great thanks.
Brian.
GPz1100B1
garyd
#2 PostAuthor: garyd » Wed Oct 02, 2013 10:16 pm
Pretty sure it's not a straight drop in mod as the buckets are different heights...I think.
Might be worth coughing up £250 for a whole head and just swapping everything over.....
#3 PostAuthor: zed1015 » Wed Oct 02, 2013 10:40 pm
They drop straight in. Just check for clearance at the bucket bores.
Spitting a shim is remote and the main cause of that is with very high lift race cams that cause the shim edge to rock on the bucket groove that runs around the inside of the shim recess, this creates a tiddly wink effect that allows the shim to lift and the cam lobe flicks them out.
Before under bucket shims were available tuners used to fill in the groove with silver solder etc to prevent this.
Big Fluff
#4 PostAuthor: Big Fluff » Thu Oct 03, 2013 9:49 am
zed1015 wrote:They drop straight in. Just check for clearance at the bucket bores.
+1 :up
I've just fitted Unitrak cams in my GPz1100B1 motor and there were no problems whatsoever!
Will
martinz1000r
#5 PostAuthor: martinz1000r » Thu Oct 03, 2013 1:50 pm
+2. Unitrak cams in Z1000R. Straight swap. Good luck finding them though!
garyd
#6 PostAuthor: garyd » Thu Oct 03, 2013 8:44 pm
Ha...shows what I know :oops: :roll:
BRIAN S
#7 PostAuthor: BRIAN S » Thu Oct 03, 2013 9:19 pm
Cheers guys Thanks for the advice :up
GPz1100B1
Users browsing this forum: Bing [Bot] and 120 guests
