Z1100R PROJECT HELP NEEDED
nakasaki
#1 PostAuthor: nakasaki » Mon Oct 14, 2013 10:18 pm
i am new to this club and would appriciate some help,just purchased an original 1983 1100r and its going to get a revamp with zrx 1200 front and back end ( i have a full donor bike )has any one fitted a swing arm into this frame and also the front end ie top and bottom yokes into the headstock.i have heard that a zx10b model front sprocket is offset enough for the chain alighnment is this correct..cheers richy
#2 PostAuthor: zed1015 » Mon Oct 14, 2013 10:43 pm
You should re-post this in the BIKE HELP section for a better response.
The ZRX running gear transplant is a common mod so you should soon get the info you need.
weaver
#3 PostAuthor: weaver » Mon Oct 14, 2013 11:50 pm
front end goes straight in,the 1100r and ZRX use the same bearings,the swingarm fits,you will need to use the elr swingarm shaft and use a sleeve so it fits the bigger i.d bearings fitted to the zrx arm.
I've tried a lot of different front sprockets,the zrx will fit,from memory I think the one I have now is zzr1100 to give me std ELR teeth (15) as I couldnt find a 15t for the ZRX,I have an approx 10mm spacer behind the front sprocket to line up with rear.
tlc
#4 PostAuthor: tlc » Tue Oct 15, 2013 5:28 am
If the 1100R is indeed original do not get rid of any of the parts. They are increasingly rare and valuable.
Why not do this to a J or GPz?
nakasaki
#5 PostAuthor: nakasaki » Tue Oct 15, 2013 8:52 am
just noticed i posted this in the wrong section,the help i have been given already is a start thanks guys
i know this conversion is not to everyones taste especially zed lovers but i will be keeping all the 11r running gear to return to standard as i know how rare the wheels are..
any little bits of info is appriciated to save time and money,once i have worked out what to do i will add some photos of the build cheers richy..
#6 PostAuthor: paul doran » Tue Oct 15, 2013 9:59 am
a few pictures when You can please
Taffus
#7 PostAuthor: Taffus » Tue Oct 15, 2013 10:11 am
you'll have to widen the top shock mounts to match the extra width of the swing arm. my 1100R frame was done by A & H performance.
tlc
#8 PostAuthor: tlc » Tue Oct 15, 2013 11:34 am
Or use an XJR swingarm and a narrower wheel rim.
Robw
#9 PostAuthor: Robw » Tue Oct 15, 2013 6:38 pm
I have done this and I have pm'd you.
Rob
pluto
#10 PostAuthor: pluto » Tue Oct 15, 2013 6:50 pm
Hi,
Not sure about the 'original 1100r 1983' as far as I was aware only the 1000R was available in 83 the 11 was 84/5 - So it doesn't matter if you chop it up after all. :D
nakasaki
#11 PostAuthor: nakasaki » Wed Oct 16, 2013 10:02 pm
correction my mistake it's a 1984-1985 on a c plate
jphaynes669
#12 PostAuthor: jphaynes669 » Thu Oct 17, 2013 8:49 pm
Pictures please asap......when you can....no rush! :lol: :wink:
Jeff.H
Users browsing this forum: Maunders and 81 guests
