z1bman wrote:are you going to check the pistons / bore & rings while you have the head removed ?
Will do when I buy the tools, after Xmas. What will I need?
(Buying new pistons / rings, but need gauge(s) for bores / ring gaps)
zed1015 wrote:You will need some feeler gauges to check ring gaps.
If fitting new rings the bores will need a light hone.
You will need a bore gauge and external mic for checking piston/bore clearance.
Unless you are planning on doing quite a few more engines the cost of equipment for anything beyond honing and re-ringing will far outweigh the cost of taking the block to be checked at a shop.
ADRIAN H wrote:Talk to VDUK (Ralph - SW Area Rep) http://www.bikerstoolbox.co.uk/ Discount for club members.
Users browsing this forum: No registered users and 202 guests
