GPz1100 Uni Rotor Removal Help
LTD Project
Anyone in the York Area got and can lend a tool to get the Alternator rotor off the Crank?
Or suggest other solution that doesn't break anything?
I am just north of York
KZ1000 B4 under light restoration.
The extractor / puller thread is 18 x 1.25mm same as the rear wheel spindle.
Dont be tempted to use the spindle with a weight to slide hammer it off. It will tear the knock pins out of the main bearing housings in the crankcase.
Its easy enough to make one or have one made but you will need to hold the rotor correctly or you will destroy it.
Main dealer may be able to help with the proper tool.
http://www.z1ownersclub.co.uk/forum/vie ... or+removal
LTD Project
Thanks Marlin, but ended up getting a tool from Ralph (bikers toolkit).
Now got to work out how to use it properly, I tried doing it up real tight then hitting the end with a hammer..... No joy
Dont want to damage end of crank, i think I read somewhere about putting a ball bearing in first before screwing the tool in.
What is the correct approach to using the tool / removing the rotor?
This bike has cost enough without doing something dreadful to the end of the crank.
Thanks again
Thanks again
LTD Project
why are you removing rotor ? new rotor ? engine rebuild ? big hit's on the end of the crank . BIG NO NO !!!!!! , use a strap that you would tie a bike down in the back of a van . round the rotor a piece of metal in to the floor . no big hit's to the crank , screw extractor in to rotor . no problem , cheers marlin
LTD Project
Yes Marlin
The whole thing is coming apart and I will do what I can to refurb the engine internals that need it.
I have found a way of holding tight the rotor whilst screwing in the tool but rotor just will not budge, so tight is the tool now that I cannot remove it so now dont know what to do.....
Have progressed with the rest of the strip down, with out further problem but tool is still stuck out of the end of the rotor, i feel such a noob at times!
as a last resort get some heat on to the centre part of the rotor. if you are striping the motor wait until you remove the crank then put it in a vice to hold it then you will be able to get some better tension on the puller. if the puller is stuck it has probably started to strip the thread on the puller if its a cheap one as the Kawasaki tool is hardened
LTD Project
Don't hit the rotor or extractor with an hammer and using a normal length spanner sometimes isn't enough.
If it really is that tight don't use anything on the rotor to lock it as it can distort , you need to find another way of holding the crank.
If you are stripping the bike anyway then pull the crank out of the cases and get it in the vice.
Use a 3 foot breaker bar, if the extractor is good quality it won't strip its threads and the rotor will pop off.
