zpower wrote:The tank, side panels and tailpiece are now mounted.
The tubes have been moved to follow the line of the side panels better.
The cross frame braces are in to add strength and support the seat and tailpiece.
[img]http://i1274.photobucket.com/albums/y429/zpower-images/Zed-Project/IMG_1339_zpsfb81f6cc.j
My mate took a picture of me trying it out for size
Shame the front tyre is flat
id keep an eye out that the chain misses the top of the arm when it mates up with the front sprocket
Phil.
The ZPower Project
neilbarrett
- ZedHead
Hi Neil,
The weight of the engine should shallow out the swinging arm a little and I'm currently thinking about a 17/46 530 sprocket setup but was going to ask that question a little closer to the time but if anyone has some input on this I would appreciate it.
17" rear 180/55 so with a 17/46 530 i'm thinking flat out would be around 120mph but will accelerate quite hard with the 1200 top end?
Phil.
Phil.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
Hi Rob,
The main reason was clearance between the chain and the top of the swinging arm.
Anyone else running 17" wheels with a 530 chain conversion want to post their gearing and what it pulls like?
Phil.
Phil.
Thanks for the suggestion tlc
If I have any issues I have a few options two of which being increase the length of the forks to put more weight on the back or make some new dog legs to drop the rear a little.
This requirement will be driven by the size of the sprockets I use etc...
Phil.
Phil.
Frame engine mounts and gussets / bracing done and frame jigged. Welds need tidying up.
Over all view of the modded frame
Now I can progress the blind build to see what additional brakets etc I will need.
Brake callipers were in a sorry state so I set to work on them...
Before...
Using the piston extraction tool that I borrowed from Fred the Zed cheers Rich
Cleaned and painted...
Finished...
Another job ticked off the list
Before...
Finished...
Vince2 wrote:Very impressive Phil. Trust it didn't 'BRAKE' the bank!
It's the cheapest bit of restoration so far
sanderz wrote:That frames looking top notch there Zpower, lot of work gone into that. Keep it going.
Thanks glad you like it
Users browsing this forum: No registered users and 328 guests
