Dyna s full advance
Dyna s full advance
#1 PostAuthor: PAULJAC47 » Wed Dec 18, 2013 5:26 pm
Guyz sure this has been raised before,my b3 z1000 project came fitted with dyna s ,came to set and will not go to full advance marks,even though i am at the limit in the plate and have moved the half moon pickups as far as they will go,have set these before with no probs,i am setting with a strobe and have marked full advance with tippex just by the number 4,,Any thoughts,,PaulJ
#2 PostAuthor: zed1015 » Wed Dec 18, 2013 6:07 pm
It's the ROTOR.
It will have '3' or '3A' stamped on it.
Which ever one you have is wrong and you need the other one.
#3 PostAuthor: PAULJAC47 » Wed Dec 18, 2013 6:19 pm
Thanks Zed are there only two rotor variations? as i have a complete set up that came off a z900...Paul J
#4 PostAuthor: zed1015 » Wed Dec 18, 2013 6:45 pm
Only two different rotors.
It's because of the advancer.
The early ones were 5 to 40 degrees and the later were 10 to 40 degrees.
Changing the advancer for an early or later one depending on what's fitted will have the same effect as changing the rotor.
#5 PostAuthor: z1bman » Wed Dec 18, 2013 6:53 pm
z1000b3 uses 211481003
z900a4 uses 21148010
Users browsing this forum: No registered users and 163 guests
