Mikuni 33mm smoothbore float height
Padders
#1 PostAuthor: Padders » Wed Jan 01, 2014 11:09 am
Can anyone help me with the float height setting for my 33mm smoothbores.
PUM 13
#2 PostAuthor: ADRIAN H » Wed Jan 01, 2014 11:28 am
Padders
#3 PostAuthor: Padders » Wed Jan 01, 2014 12:59 pm
Cheers Adrian but nothing on the 33mm float height. I have set mine at 24mm and fuel is coming out of all four carbs. Float needles look fine and its rare for all four to leak at the same time.
Any ideas guys.
PUM 13
#4 PostAuthor: zed1015 » Wed Jan 01, 2014 1:38 pm
Correct float height is 22mm to 24mm.
Padders
#5 PostAuthor: Padders » Wed Jan 01, 2014 2:05 pm
Thanks Rob will have a go at 23mm
PUM 13
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Wed Jan 01, 2014 7:47 pm
Have sent you an email with the vm33 manual. thought it might come in handy.
Padders
#7 PostAuthor: Padders » Wed Jan 01, 2014 8:05 pm
Thanks Phil,
Looks like all four float vales are worn so I have ordered a new set of 2.8 ones on line from NRP this afternoon.
Thanks again will print off and have a good read.
PUM 13
Toyboy
#8 PostAuthor: Toyboy » Thu Jan 02, 2014 9:58 pm
KWACKERZ1 wrote:Have sent you an email with the vm33 manual. thought it might come in handy.
Hi could i be cheeky and ask for a copy of the manual to please :D
Toyboy
#9 PostAuthor: Toyboy » Thu Jan 02, 2014 10:01 pm
Padders wrote:Thanks Phil,
I had a set with exactly the same problem when i first filled them with fuel.
I tapped the float bowls and then they stopped leaking. Floats were sticking
