MOT Questions on Custom Build
Royalratch
Hi all.
can anyone help with this:
1) Do both front and rear brake need to have switches for brake light?
2) Do you need to have a kill switch - if so can it be 'hidden'
3) If you have keyless ignition (but push button starter) does the key fob transponder also act as kill?
Cheers in advance!
Cheers in advance!
1. Bikes pre 1986 need only one brake light switch and can be operated from either front or rear ( Post 86 need both front and rear brake switches if originally fitted)
2. A kill switch is not compulsory .
3. Haven't a clue about the key fob transponder.
Royalratch
- z1000puddin
zed1015 wrote:1. Bikes pre 1986 need only one brake light switch and it must be operated from the front brake ( Post 86 need both front and rear brake switches if originally fitted)
My black zed has never had a front brake light switch - Only the rear and has been through various MOT testing stations since 1996 and passed ??
Stu
Zed til Dead
z1000puddin wrote:zed1015 wrote:1. Bikes pre 1986 need only one brake light switch and it must be operated from the front brake ( Post 86 need both front and rear brake switches if originally fitted)
Stu
OOPS! My balls up.
Should have said either front or back and have amended the post accordingly.
Off the front is preferable though as it's the one that's used the most.
jimmock wrote:Jay1969 wrote:Pigford wrote:Think Rob meant REAR
Pigford, that's my alternative to "tail light".
I always always say "rear light" instead of "tail light".
Is that the RED one at the back??
Jimmock, I always always prefer red lenses on vehicle rear
lights to those modern clear translucent plastic one's.
Jay1969 wrote:jimmock wrote:Jay1969 wrote:Pigford wrote:Think Rob meant REAR
I agree.
Red is best!!
Jimmock.
I hate people I don't like !
That is fat tyre you have there. I approve, like the tail light too. Ace. .
